In reply to kvenkatv:
This should get you started
package global_types;
typedef bit [31:0] uint;
typedef uint uint_da[];
endpackage
module bot;
import global_types::*;
uint sig;
module top;
bit clk;
uint_da encodings = onehots();
function uint_da onehots;
onehots = new[32];
foreach (onehots[i]) onehots[i] = 32'b1 << i;
endfunction : onehots
covergroup cg(ref uint arg) @(posedge clk);
option.per_instance = 1;
coverpoint arg {
bins b[] = encodings;
endgroup : cg
genvar i;
for (i = 0; i<32;i++) begin : g_regs
bot u();
cg cg_inst;
initial cg_inst = new(g_regs[i].u.sig);
endmodule : top
