Why is the read data different from write?
This is from one of the examples in verification academy. Can any one tell why is the read data different?
package bidirect_bus_pkg;
`include "uvm_macros.svh"
// Bus sequence item
class bus_seq_item extends uvm_sequence_item;
// Request fields
rand logic[31:0] addr;
rand logic[31:0] write_data;
rand bit read_not_write;
rand int delay;
// Response fields
bit error;
logic[31:0] read_data;
`uvm_object_utils(bus_seq_item)
function new(string name = "bus_seq_item");
constraint at_least_1 { delay inside {[1:20]};}
constraint align_32 {addr[1:0] == 0;}
function void do_copy(uvm_object rhs);
  bus_seq_item rhs_;
  if (!$cast(rhs_, rhs)) begin
    `uvm_fatal("do_copy", "cast failed, check types");
  addr = rhs_.addr;
  write_data = rhs_.write_data;
  read_not_write = rhs_.read_not_write;
  delay = rhs_.delay;
  error = rhs_.error;
  read_data = rhs_.read_data;
endfunction: do_copy
function bit do_compare(uvm_object rhs, uvm_comparer comparer);
  bus_seq_item rhs_;
  do_compare = $cast(rhs_, rhs) &&
               super.do_compare(rhs, comparer) &&
               addr == rhs_.addr &&
               write_data == rhs_.write_data &&
               read_not_write == rhs_.read_not_write &&
               delay == rhs_.delay &&
               error == rhs_.error &&
               read_data == rhs_.read_data;
endfunction: do_compare
function string convert2string();
  return $sformatf("%s\n addr:\t%0h\n write_data:\t%0h\n read_not_write:\t%0b\n delay:\t%0d\n error:\t%0b\n read_data:\t%0h",
                    super.convert2string(), addr, write_data, read_not_write, delay, error, read_data);
endfunction: convert2string
function void do_print(uvm_printer printer);
  printer.m_string = convert2string();
endfunction: do_print
function void do_record(uvm_recorder recorder);
  super.do_record(recorder);
  `uvm_record_field("addr", addr);
  `uvm_record_field("write_data", write_data);
  `uvm_record_field("read_not_write", read_not_write);
  `uvm_record_field("delay", delay);
  `uvm_record_field("error", error);
  `uvm_record_field("read_data", read_data);
endfunction: do_record
endclass: bus_seq_item
// Bidirectional driver - uses:
// get_next_item() to get the next instruction item
// item_done() to indicate that the driver has finished with the item
class bidirect_bus_driver extends uvm_driver #(bus_seq_item);
`uvm_component_utils(bidirect_bus_driver)
bus_seq_item req;
local virtual bidirect_bus_driver_bfm m_bfm;
function new(string name = "bidirect_bus_driver", uvm_component parent = null);
function void set_bfm(virtual bidirect_bus_driver_bfm bfm);
  m_bfm = bfm;
endfunction: set_bfm
  m_bfm.wait_for_reset();
    seq_item_port.get_next_item(req); // Start processing req item
    m_bfm.drive(req);
    seq_item_port.item_done(); // End of req item
endtask: run_phase
endclass: bidirect_bus_driver
class bidirect_bus_sequencer extends uvm_sequencer #(bus_seq_item);
`uvm_component_utils(bidirect_bus_sequencer)
function new(string name = "bidirect_bus_sequencer", uvm_component parent = null);
endclass: bidirect_bus_sequencer
// Bus sequence, which shows how the req object contains the result at the end
// of the control handshake with the driver via the sequencer
class bus_seq extends uvm_sequence #(bus_seq_item);
`uvm_object_utils(bus_seq)
bus_seq_item req;
int error_count = 0;
rand int limit = 15; // Controls the number of iterations
logic[31:0] mem[32'h0100_0000:32'h0100_001C] = '{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
function new(string name = "bus_seq");
task body;
  req = bus_seq_item::type_id::create("req");
  repeat (limit) begin
    start_item(req);
    // The address is constrained to be within the address of the GPIO function
    // within the DUT, The result will be a request item for a read or a write
    assert(req.randomize() with {addr inside {[32'h0100_0000:32'h0100_001C]};});
    finish_item(req);
    // The req handle points to the object that the driver has updated with response data
    `uvm_info("seq_body", req.convert2string(), UVM_LOW);
	if(req.read_not_write == 1) begin
	  if (mem[req.addr] == req.read_data) begin
	  `uvm_info("seq_body", "READ WRITE MATCH", UVM_LOW)
      else begin
		error_count++;
		`uvm_error("body", "READ WRITE ERROR")
    else begin
	  mem[req.addr] = req.write_data;
endtask: body
endclass: bus_seq
// Test class which instantiates, builds and connects the sequencer and the driver
class bidirect_bus_test extends uvm_test;
`uvm_component_utils(bidirect_bus_test)
bus_seq                test_seq;
bidirect_bus_driver    m_driver;
bidirect_bus_sequencer m_sequencer;
function new(string name = "bidirect_bus_test", uvm_component parent = null);
  m_driver = bidirect_bus_driver::type_id::create("m_driver", this);
  m_sequencer = bidirect_bus_sequencer::type_id::create("m_sequencer", this);
endfunction: build_phase
  virtual bidirect_bus_driver_bfm bfm;
  m_driver.seq_item_port.connect(m_sequencer.seq_item_export);
  if (!uvm_config_db #(virtual bidirect_bus_driver_bfm)::get(this, "", "top_hdl.bidirect_bus_drv", bfm)) begin
    `uvm_fatal("connect_phase", "uvm_config_db #(virtual bidirect_bus_driver_bfm)::get(...) failed");
  m_driver.set_bfm(bfm);
endfunction: connect_phase
  test_seq = bus_seq::type_id::create("test_seq");
  phase.raise_objection(this, "Starting test_seq");
  test_seq.start(m_sequencer);
  phase.drop_objection(this, "Finished test_seq");
endtask: run_phase
function void report_phase(uvm_phase phase);
  if(test_seq.error_count == 0) begin
    `uvm_info("** UVM TEST PASSED **", $sformatf("No Read Write mismatches"), UVM_LOW)
  else begin
    `uvm_error("** UVM TEST FAILED **", $sformatf("Read Write mismatches"))
endclass: bidirect_bus_test
endpackage: bidirect_bus_pkg
// Top level test bench module
module top_tb;
import bidirect_bus_pkg::*;
// UVM start up:
  run_test("bidirect_bus_test");
endmodule: top_tb
module top_hdl;
bus_if  BUS();
gpio_if GPIO();
bidirect_bus_driver_bfm bidirect_bus_drv(
   .clk        (BUS.clk),
   .resetn     (BUS.resetn),
   .addr       (BUS.addr),
   .write_data (BUS.write_data),
   .rnw        (BUS.rnw),
   .valid      (BUS.valid),
   .ready      (BUS.ready),
   .read_data  (BUS.read_data),
   .error      (BUS.error)
bidirect_bus_slave DUT(.bus(BUS), .gpio(GPIO));
// Free running clock
  BUS.clk = 0;
    #10 BUS.clk = ~BUS.clk;
// Reset
  BUS.resetn = 0;
  repeat (3) begin
    @(posedge BUS.clk);
  BUS.resetn = 1;
  uvm_pkg::uvm_config_db #(virtual bidirect_bus_driver_bfm)::set(null, "uvm_test_top", $psprintf("%m.bidirect_bus_drv") , bidirect_bus_drv);
endmodule: top_hdl
interface bus_if;
logic clk;
logic resetn;
logic[31:0] addr;
logic rnw;
logic valid;
logic ready;
logic error;
endinterface: bus_if
interface gpio_if;
logic[255:0] gp_op;
logic[255:0] gp_ip;
logic clk;
endinterface: gpio_if
interface bidirect_bus_driver_bfm (
   input  logic        clk,
   input  logic        resetn,
   output logic [31:0] addr,
   output logic [31:0] write_data,
   output logic        rnw,
   output logic        valid,
   input  logic        ready,
   input  logic [31:0] read_data,
   input  logic        error
  valid <= 0;
  rnw <= 1;
task wait_for_reset();
  @(posedge resetn);
endtask: wait_for_reset
task drive(bus_seq_item req);
  repeat (req.delay) begin // Delay between bus transactions
    @(posedge clk);
  valid <= 1;
  addr <= req.addr;
  rnw <= req.read_not_write;
  if (req.read_not_write == 0) begin
     write_data <= req.write_data;
  while (ready != 1) begin
    @(posedge clk);
  // At end of the pin level bus transaction
  // Copy response data into the req fields:
  if (req.read_not_write == 1) begin
    req.read_data = read_data; // Copy read data response
  req.error = error; // Copy bus error response status
  valid <= 0; // End the pin level bus transaction
endtask: drive
endinterface: bidirect_bus_driver_bfm
// DUT - A semi-real GPIO interface with a scratch RAM
module bidirect_bus_slave(interface bus, interface gpio);
logic[1:0] delay;
always @(posedge bus.clk) begin
  if (bus.resetn == 0) begin
    delay <= 0;
    bus.ready <= 0;
    gpio.gp_op <= 0;
  if (bus.valid == 1) begin // Valid cycle
    if (bus.rnw == 0) begin // Write
      if (delay == 2) begin
        bus.ready <= 1;
        delay <= 0;
        if (bus.addr inside{[32'h0100_0000:32'h0100_001C]}) begin // GPO range - 8 words or 255 bits
          case (bus.addr[7:0])
            8'h00: gpio.gp_op[31:0] <= bus.write_data;
            8'h04: gpio.gp_op[63:32] <= bus.write_data;
            8'h08: gpio.gp_op[95:64] <= bus.write_data;
            8'h0c: gpio.gp_op[127:96] <= bus.write_data;
            8'h10: gpio.gp_op[159:128] <= bus.write_data;
            8'h14: gpio.gp_op[191:160] <= bus.write_data;
            8'h18: gpio.gp_op[223:192] <= bus.write_data;
            8'h1c: gpio.gp_op[255:224] <= bus.write_data;
          endcase
          bus.error <= 0;
        else begin
          bus.error <= 1; // Outside valid write address range
      else begin
        delay <= delay + 1;
        bus.ready <= 0;
    else begin // Read cycle
      if (delay == 3) begin
        bus.ready <= 1;
        delay <= 0;
            8'h00: bus.read_data <= gpio.gp_op[31:0];
            8'h04: bus.read_data <= gpio.gp_op[63:32];
            8'h08: bus.read_data <= gpio.gp_op[95:64];
            8'h0c: bus.read_data <= gpio.gp_op[127:96];
            8'h10: bus.read_data <= gpio.gp_op[159:128];
            8'h14: bus.read_data <= gpio.gp_op[191:160];
            8'h18: bus.read_data <= gpio.gp_op[223:192];
            8'h1c: bus.read_data <= gpio.gp_op[255:224];
          endcase
          bus.error <= 0;
        else if (bus.addr inside{[32'h0100_0020:32'h0100_003C]}) begin // GPI range - 8 words or 255 bits - read only
            8'h20: bus.read_data <= gpio.gp_ip[31:0];
            8'h24: bus.read_data <= gpio.gp_ip[63:32];
            8'h28: bus.read_data <= gpio.gp_ip[95:64];
            8'h2c: bus.read_data <= gpio.gp_ip[127:96];
            8'h30: bus.read_data <= gpio.gp_ip[159:128];
            8'h34: bus.read_data <= gpio.gp_ip[191:160];
            8'h38: bus.read_data <= gpio.gp_ip[223:192];
            8'h3c: bus.read_data <= gpio.gp_ip[255:224];
          endcase
          bus.error <= 0;
        else begin
          bus.error <= 1;
      else begin
        delay <= delay + 1;
        bus.ready <= 0;
  else begin
    bus.ready <= 0;
    bus.error <= 0;
    delay <= 0;
endmodule: bidirect_bus_slave
In reply to rag123:
Can you explain what differences you see? There are no constraints to read only what was written.
Dave,
Here is the results :
addr: 1000018
write_data: 878d8a46
read_not_write: 0
delay: 2
error: 0
read_data: xxxxxxxx
UVM_INFO testbench.sv(207) @ 530: uvm_test_top.m_sequencer@@test_seq [seq_body]
addr: 1000008
write_data: 7870e12
read_not_write: 0
delay: 14
error: 0
read_data: xxxxxxxx
UVM_INFO testbench.sv(207) @ 650: uvm_test_top.m_sequencer@@test_seq [seq_body]
addr: 100000c
write_data: 869889d
read_not_write: 1
delay: 1
error: 0
read_data: 0
UVM_INFO testbench.sv(210) @ 650: uvm_test_top.m_sequencer@@test_seq [seq_body] READ WRITE MATCH
UVM_INFO testbench.sv(207) @ 950: uvm_test_top.m_sequencer@@test_seq [seq_body]
addr: 1000018
write_data: 15d49c1d
read_not_write: 1
delay: 10
error: 0
read_data: 878d8a46
UVM_INFO testbench.sv(210) @ 950: uvm_test_top.m_sequencer@@test_seq [seq_body] READ WRITE MATCH
UVM_INFO testbench.sv(207) @ 1090: uvm_test_top.m_sequencer@@test_seq [seq_body]
addr: 1000004
write_data: c30010a9
read_not_write: 0
delay: 3
error: 0
read_data: 878d8a46
UVM_INFO testbench.sv(207) @ 1270: uvm_test_top.m_sequencer@@test_seq [seq_body]
addr: 100000c
write_data: 6970db91
read_not_write: 1
delay: 4
error: 0
read_data: 0
UVM_INFO testbench.sv(210) @ 1270: uvm_test_top.m_sequencer@@test_seq [seq_body] READ WRITE MATCH
UVM_INFO testbench.sv(207) @ 1550: uvm_test_top.m_sequencer@@test_seq [seq_body]
addr: 1000000
write_data: f1eb0346
read_not_write: 1
delay: 9
error: 0
read_data: 0
UVM_INFO testbench.sv(210) @ 1550: uvm_test_top.m_sequencer@@test_seq [seq_body] READ WRITE MATCH
UVM_INFO testbench.sv(207) @ 1890: uvm_test_top.m_sequencer@@test_seq [seq_body]
addr: 100001c
write_data: 46ddc0ca
read_not_write: 1
delay: 12
error: 0
read_data: 0
UVM_INFO testbench.sv(210) @ 1890: uvm_test_top.m_sequencer@@test_seq [seq_body] READ WRITE MATCH
UVM_INFO testbench.sv(207) @ 2090: uvm_test_top.m_sequencer@@test_seq [seq_body]
addr: 1000018
write_data: 4abe9da4
read_not_write: 0
delay: 6
error: 0
read_data: 0
UVM_INFO testbench.sv(207) @ 2490: uvm_test_top.m_sequencer@@test_seq [seq_body]
addr: 1000018
write_data: 21e2c4
read_not_write: 1
delay: 15
error: 0
read_data: 4abe9da4
UVM_INFO testbench.sv(210) @ 2490: uvm_test_top.m_sequencer@@test_seq [seq_body] READ WRITE MATCH
UVM_INFO testbench.sv(207) @ 2870: uvm_test_top.m_sequencer@@test_seq [seq_body]
addr: 100001c
write_data: 9e082254
read_not_write: 0
delay: 15
error: 0
read_data: 4abe9da4
UVM_INFO testbench.sv(207) @ 3130: uvm_test_top.m_sequencer@@test_seq [seq_body]
addr: 1000000
write_data: 8109a3c7
read_not_write: 1
delay: 8
error: 0
read_data: 0
UVM_INFO testbench.sv(210) @ 3130: uvm_test_top.m_sequencer@@test_seq [seq_body] READ WRITE MATCH
UVM_INFO testbench.sv(207) @ 3490: uvm_test_top.m_sequencer@@test_seq [seq_body]
addr: 1000000
write_data: 61fa584c
read_not_write: 1
delay: 13
error: 0
read_data: 0
UVM_INFO testbench.sv(210) @ 3490: uvm_test_top.m_sequencer@@test_seq [seq_body] READ WRITE MATCH
UVM_INFO testbench.sv(207) @ 3830: uvm_test_top.m_sequencer@@test_seq [seq_body]
addr: 1000018
write_data: 3e4e8e78
read_not_write: 1
delay: 12
error: 0
read_data: 4abe9da4
UVM_INFO testbench.sv(210) @ 3830: uvm_test_top.m_sequencer@@test_seq [seq_body] READ WRITE MATCH
UVM_INFO testbench.sv(207) @ 4130: uvm_test_top.m_sequencer@@test_seq [seq_body]
addr: 1000010
write_data: 227ed1f1
read_not_write: 1
delay: 10
error: 0
read_data: 0
In reply to rag123:
Maybe you do not understand how the testbench works. The bus_seq_item has a random write_data that only gets used when read_not_write is 0. And read_data is only used when read_not_write is 1. They will (almost) never have the same value in the same transaction.
