Hi!
I am trying to compile my UVM code, when I get the error Uxexpected SystemVerilog keywork “package”.
I was looking for a missing semicolon or some syntax error in my code, but I could not find anything.
I attach my code and the error obtained. The code is very extensive, so I attach the testbench, include and package files. Also the .do and a extract of the transcript with the error obtanied. Thanks!
`timescale 1ps/1ps
`timescale 1ps/1ps
`include "uvm_macros.svh"
`include "../testbench/includes.sv"
//class: testbench
module testbench;
import define_pkg::*;
import test_pkg::*;
int log_file_asserts_h;
// Variable: log_file_h
// Handler to log file.
int log_file_h;
// Variable: test_name
// Test name string to compose log file name.
string test_name;
// Variable: msg
// Auxiliary string.
string msg;
// Variable: current_step
// Step number printed in reports.
int current_step = 1;
wire [3:0] dut_to_flash_cle;
wire [3:0] dut_to_flash_ale;
wire [3:0] dut_to_flash_nwe;
wire dut_to_flash_nwp;
wire [7:0] dut_to_flash_nce_0_1;
wire [7:0] dut_to_flash_nce_2_3;
wire [3:0] dut_to_flash_nre;
wire [15:0] dut_to_flash_data_0_1;
wire [15:0] dut_to_flash_data_2_3;
wire [7:0] dut_to_flash_rnb;
wire [7:0] dut_to_flash_chan_sel;
wire [17:0] dut_to_sram_address;
wire [15:0] dut_to_sram_data;
wire dut_to_sram_ce0;
wire dut_to_sram_ce1;
wire dut_to_sram_oe;
wire dut_to_sram_we;
wire dut_to_hk_spw_dout_o;
wire dut_to_hk_spw_sout_o;
wire dut_to_hk_spw_din_i;
wire dut_to_hk_spw_sin_i;
wire dut_to_sci_spw_dout_o;
wire dut_to_sci_spw_sout_o;
wire dut_to_sci_spw_din_i;
wire dut_to_sci_spw_sin_i;
wire dut_to_out_spw_dout_o;
wire dut_to_out_spw_sout_o;
wire dut_to_out_spw_din_i;
wire dut_to_out_spw_sin_i;
wire dut_to_hk_spw_dout_no;
wire dut_to_hk_spw_sout_no;
wire dut_to_sci_spw_dout_no;
wire dut_to_sci_spw_sout_no;
wire dut_to_out_spw_dout_no;
wire dut_to_out_spw_sout_no;
wire [16:0] dut_to_mram_address_o;
wire [7:0] dut_to_mram_data_io;
wire dut_to_mram_ce0_no;
wire dut_to_mram_ce1_no;
wire dut_to_mram_ce2_no;
wire dut_to_mram_ce3_no;
wire dut_to_mram_oe_no;
wire dut_to_mram_we_no;
clock_reset_intf vintf_clock_reset();
dh_fpga_intf vintf_dh_fpga();
flash_intf vintf_flash();
mram_intf vintf_mram();
sram_intf vintf_sram();
hk_spw_intf vintf_hk_spw();
sci_spw_intf vintf_sci_spw();
out_spw_intf vintf_out_spw();
assign dut_to_flash_cle = m_flash_intf.flash_cle_o;
assign dut_to_flash_ale = m_flash_intf.flash_ale_o;
assign dut_to_flash_nwe = m_flash_intf.flash_nwe_o;
assign dut_to_flash_nwp = m_flash_intf.flash_nwp_o;
assign dut_to_flash_nce_0_1 = m_flash_intf.flash_nce_0_1_o;
assign dut_to_flash_nce_2_3 = m_flash_intf.flash_nce_2_3_o;
assign dut_to_flash_nre = m_flash_intf.flash_nre_o;
assign dut_to_flash_data_0_1 = m_flash_intf.flash_data_0_1_io;
assign dut_to_flash_data_2_3 = m_flash_intf.flash_data_2_3_io;
assign dut_to_flash_rnb = m_flash_intf.flash_rnb_i;
assign dut_to_flash_chan_sel = m_flash_intf.flash_chan_sel_o;
assign dut_to_sram_address = m_sram_intf.sram_address;
assign dut_to_sram_data = m_sram_intf.sram_data;
assign dut_to_sram_ce0 = m_sram_intf.sram_ce0;
assign dut_to_sram_ce1 = m_sram_intf.sram_ce1;
assign dut_to_sram_oe = m_sram_intf.sram_oe;
assign dut_to_sram_we = m_sram_intf.sram_we;
assign dut_to_hk_spw_dout_o = m_hk_spw_intf.hk_spw_dout_o;
assign dut_to_hk_spw_sout_o = m_hk_spw_intf.hk_spw_sout_o;
assign dut_to_hk_spw_din_i = m_hk_spw_intf.hk_spw_din_i;
assign dut_to_hk_spw_sin_i = m_hk_spw_intf.hk_spw_sin_i;
assign dut_to_sci_spw_dout_o = m_sci_spw_intf.sci_spw_dout_o;
assign dut_to_sci_spw_sout_o = m_sci_spw_intf.sci_spw_sout_o;
assign dut_to_sci_spw_din_i = m_sci_spw_intf.sci_spw_din_i;
assign dut_to_sci_spw_sin_i = m_sci_spw_intf.sci_spw_sin_i;
assign dut_to_out_spw_dout_o = m_out_spw_intf.out_spw_dout_o;
assign dut_to_out_spw_sout_o = m_out_spw_intf.out_spw_sout_o;
assign dut_to_out_spw_din_i = m_out_spw_intf.out_spw_din_i;
assign dut_to_out_spw_sin_i = m_out_spw_intf.out_spw_sin_i;
assign dut_to_mram_address_o = m_mram_intf.mram_address_o;
assign dut_to_mram_data_io = m_mram_intf.mram_data_io;
assign dut_to_mram_ce0_no = m_mram_intf.mram_ce0_no;
assign dut_to_mram_ce1_no = m_mram_intf.mram_ce1_no;
assign dut_to_mram_ce2_no = m_mram_intf.mram_ce2_no;
assign dut_to_mram_ce3_no = m_mram_intf.mram_ce3_no;
assign dut_to_mram_oe_no = m_mram_intf.mram_oe_no;
assign dut_to_mram_we_no = m_mram_intf.mram_we_no;
top_wrapper u_top_wrapper(
vintf_clock_reset,
vintf_dh_fpga,
vintf_flash,
vintf_mram,
vintf_sram,
vintf_hk_spw,
vintf_sci_spw,
vintf_out_spw
// flash_bank u_flash_bank(
// .flash_cle_i (dut_to_flash_cle),
// .flash_ale_i (dut_to_flash_ale),
// .flash_nwe_i (dut_to_flash_nwe),
// .flash_nwp_i (dut_to_flash_nwp),
// .flash_nce_2_3_i (dut_to_flash_nce_2_3),
// .flash_nce_0_1_i (dut_to_flash_nce_0_1),
// .flash_nre_i (dut_to_flash_nre),
// .flash_data_2_3_io (dut_to_flash_data_2_3),
// .flash_data_0_1_io (dut_to_flash_data_0_1),
// .flash_rnb_o (dut_to_flash_rnb),
// .flash_dir_i (1'b0),
// .chan_sel_i (dut_to_flash_chan_sel)
// spw_link_tb u_hk_spw_link(
// .devrst_no(),
// .srst_o(),
// .spw_tb_dout_p_o(dut_to_hk_spw_dout_o),
// .spw_tb_dout_n_o(),
// .spw_tb_sout_p_o(dut_to_hk_spw_sout_o),
// .spw_tb_sout_n_o(),
// .spw_tb_din_p_i(dut_to_hk_spw_din_i),
// .spw_tb_din_n_i(~dut_to_hk_spw_din_i),
// .spw_tb_sin_p_i(dut_to_hk_spw_sin_i),
// .spw_tb_sin_n_i(~dut_to_hk_spw_sin_i)
// spw_sci_link u_sci_spw_link(
// .devrst_no(),
// .srst_o(),
// .spw_tb_dout_p_o(dut_to_sci_spw_dout_o),
// .spw_tb_dout_n_o(dut_to_sci_spw_dout_no),
// .spw_tb_sout_p_o(dut_to_sci_spw_sout_o),
// .spw_tb_sout_n_o(dut_to_sci_spw_sout_no),
// .spw_tb_din_p_i(dut_to_sci_spw_din_i),
// .spw_tb_din_n_i(~dut_to_sci_spw_din_i),
// .spw_tb_sin_p_i(dut_to_sci_spw_sin_i),
// .spw_tb_sin_n_i(~dut_to_sci_spw_sin_i)
// spw_out_link u_out_spw_link(
// .devrst_no(),
// .srst_o(),
// .spw_tb_dout_p_o(dut_to_out_spw_dout_o),
// .spw_tb_dout_n_o(dut_to_out_spw_dout_no),
// .spw_tb_sout_p_o(dut_to_out_spw_sout_o),
// .spw_tb_sout_n_o(dut_to_out_spw_sout_no),
// .spw_tb_din_p_i(dut_to_out_spw_din_i),
// .spw_tb_din_n_i(~dut_to_out_spw_din_i),
// .spw_tb_sin_p_i(dut_to_out_spw_sin_i),
// .spw_tb_sin_n_i(~dut_to_out_spw_sin_i)
// CY7C1061GN_10 u_sram(
// .A(dut_to_sram_address),
// .CE_b0(dut_to_sram_ce0),
// .CE_b1(dut_to_sram_ce1),
// .OE_b(dut_to_sram_oe),
// .WE_b(dut_to_sram_we),
// .DQ(dut_to_sram_data)
// MRAM_CY7C1061GN_10 u_mram(
// .CE_b0(dut_to_mram_ce0_no),
// .CE_b1(dut_to_mram_ce1_no),
// .CE_b2(dut_to_mram_ce2_no),
// .CE_b3(dut_to_mram_ce3_no),
// .WE_b(dut_to_mram_we_no),
// .OE_b(dut_to_mram_oe_no),
// .A(dut_to_mram_address_o),
// .DQ(dut_to_mram_data_io)
// Configure some simulation options.
uvm_top.enable_print_topology = 1;
uvm_top.finish_on_completion = 0;
//Get test name from CLI.
void'($value$plusargs("UVM_TESTNAME=%s",test_name));
msg={"./log_files/",test_name,".log"};
//Open file to save log messages according to selected test.
log_file_h = $fopen(msg);
if(!log_file_h) begin
`uvm_fatal("Testbench", "Unable to open log file!!!");
//Set default verbosity level for all TB components.
uvm_top.set_report_verbosity_level_hier(UVM_LOW);
msg=$sformatf("#------------------Running test: %s----------------------#",test_name);
$fdisplay(log_file_h,"#-------------------------------------------------------------#");
$fdisplay(log_file_h,msg);
$display(msg);
$fdisplay(log_file_h,"#-------------------------------------------------------------#\n");
//Set the agents' interfaces.
uvm_config_db #(virtual clock_reset_intf)::set(null, "uvm_test_top", "m_clock_reset_agent_vif", vintf_clock_reset);
uvm_config_db #(virtual dh_fpga_intf)::set(null, "uvm_test_top", "m_dh_fpga_agent_vif", vintf_dh_fpga);
uvm_config_db #(virtual flash_intf)::set(null, "uvm_test_top", "m_flash_agent_vif", vintf_flash);
uvm_config_db #(virtual mram_intf)::set(null, "uvm_test_top", "m_mram_agent_vif", vintf_mram);
uvm_config_db #(virtual sram_intf)::set(null, "uvm_test_top", "m_sram_agent_vif", vintf_sram);
uvm_config_db #(virtual hk_spw_intf)::set(null, "uvm_test_top", "m_hk_spw_agent_vif", vintf_hk_spw);
uvm_config_db #(virtual sci_spw_intf)::set(null, "uvm_test_top", "m_sci_spw_agent_vif", vintf_sci_spw);
uvm_config_db #(virtual out_spw_intf)::set(null, "uvm_test_top", "m_out_spw_agent_vif", vintf_out_spw);
//Set log file handler.
uvm_config_db #(int)::set(null, "*", "m_log_file_h", log_file_h);
// Set current step for log file.
uvm_config_db #(int)::set(null, "*", "m_curr_step", current_step);
//Run the specified test case by UVM_TEST command.
run_test();
//Close log file.
$fclose(log_file_h);
endmodule: testbench
System Verilog
`include "../tests/define_pkg.sv"
`include "../agents/clock_reset_agent/sequence_lib/clock_reset_seq_pkg.sv"
`include "../agents/clock_reset_agent/clock_reset_agent_pkg.sv"
`include "../agents/clock_reset_agent/clock_reset_intf.sv"
`include "../agents/dh_fpga_agent/sequence_lib/dh_fpga_seq_pkg.sv"
`include "../agents/dh_fpga_agent/dh_fpga_agent_pkg.sv"
`include "../agents/dh_fpga_agent/dh_fpga_intf.sv"
`include "../agents/flash_agent/sequence_lib/flash_seq_pkg.sv"
`include "../agents/flash_agent/flash_agent_pkg.sv"
`include "../agents/flash_agent/flash_intf.sv"
`include "../agents/hk_spw_agent/sequence_lib/hk_spw_seq_pkg.sv"
`include "../agents/hk_spw_agent/hk_spw_agent_pkg.sv"
`include "../agents/hk_spw_agent/hk_spw_intf.sv"
`include "../agents/mram_agent/sequence_lib/mram_seq_pkg.sv"
`include "../agents/mram_agent/mram_agent_pkg.sv"
`include "../agents/mram_agent/mram_intf.sv"
`include "../agents/out_spw_agent/sequence_lib/out_spw_seq_pkg.sv"
`include "../agents/out_spw_agent/out_spw_agent_pkg.sv"
`include "../agents/out_spw_agent/out_spw_intf.sv"
`include "../agents/sci_spw_agent/sequence_lib/sci_spw_seq_pkg.sv"
`include "../agents/sci_spw_agent/sci_spw_agent_pkg.sv"
`include "../agents/sci_spw_agent/sci_spw_intf.sv"
`include "../agents/sram_agent/sequence_lib/sram_seq_pkg.sv"
`include "../agents/sram_agent/sram_agent_pkg.sv"
`include "../agents/sram_agent/sram_intf.sv"
`include "../register_model/top_regs_pkg.sv"
`include "../environment/environment_pkg.sv"
`include "../sequences/test_seq_pkg.sv"
`include "../tests/test_pkg.sv"
ifndef DEFINE_PKG__SV
define DEFINE_PKG__SV
// Package: define_pkg
// Package for general constants.
package define_pkg;
// variable: CLK_PERIOD_NS
// Clock period in ns.
//localparam int CLK_PERIOD_NS = 20;
// // variable: ACCESS_SRAM_CYCLES
// // SRAM time access in clock cycles.
// localparam int ACCESS_SRAM_CYCLES = 1;
// // variable: ACCESS_MRAM_CYCLES
// // MRAM time access in clock cycles.
// localparam int ACCESS_MRAM_CYCLES = 0;
// // variable: N_CYCLES_SOFT_RESET
// // Number of clock cycles for soft reset active.
// localparam int N_CYCLES_SOFT_RESET = 10;
// // variable: N_CYCLES_HARD_RESET
// // Number of clock cycles for hard reset active.
// localparam int N_CYCLES_HARD_RESET = 10;
endpackage : define_pkg
`endif
.do file****
Set paths and env
set MAIN_PATH [pwd]
set WORK_LIB_DIR ./work
set WORK_LIB_NAME work
#set RTG4_LIB_DIR $MAIN_PATH/12.4_Questasim_10.7c_rtg4
#set RTG4_LIB_NAME RTG4
set TOOL C:/questasim64_10.7c/verilog_src/uvm-1.1d
set UVM_TESTRUN $1
Quit previous simulation
quit -sim
Clear transcript windows
.main clear
Close previous transcript file
transcript file “”
puts [string repeat “-” 72]
echo $MAIN_PATH
if [file exists work] {vdel -all}
if [file exists RTGA] {vdel -all}
vlib $WORK_LIB_NAME
vmap $WORK_LIB_NAME $WORK_LIB_DIR
#vlib $RTG4_LIB_NAME
#vmap $RTG4_LIB_NAME $RTG4_LIB_DIR
vcom -work work …/rtl/mm_top.vhd
vlog -coveropt 3 +cover -work work -f simTest.f +define+UVM_NO_DPI +define+UVM_REG_DATA_WIDTH=32
vsim +UVM_TESTNAME=UVM_TESTRUN -coverage -t 1ps -vopt work.testbench -c -do "coverage save -onexit -directive -codeAll coverage2.ucdb; transcript file {UVM_TESTRUN}_log.txt; add wave -position insertpoint sim:/testbench/u_top_wrapper/u_dS3r_top/*; run -all"
vsim +UVM_TESTNAME=UVM_TESTRUN -coverage -t 1ps -vopt work.testbench -c -do "coverage save -onexit -directive -codeAll coverage2.ucdb; transcript file {UVM_TESTRUN}_log.txt;"
vsim -coverage -t 1ps -vopt work.testbench -c -do “coverage save -onexit -directive -codeAll coverage2.ucdb;”
source wave_ds3r_top.do
run -all
Transcript file__
– Loading entity spw_input_top
– Loading entity buff_ctrl_top
– Loading entity amba_uart_bridge_50000000_115200
– Loading entity mram_ctrl_top
End time: 13:37:11 on May 20,2022, Elapsed time: 0:00:40
Errors: 0, Warnings: 0
QuestaSim-64 vlog 10.7c Compiler 2018.08 Aug 18 2018
Start time: 13:37:12 on May 20,2022
vlog -reportprogress 300 -coveropt 3 “+cover” -work work -f simTest.f “+define+UVM_NO_DPI” “+define+UVM_REG_DATA_WIDTH=32”
– Compiling package uvm_pkg (uvm-1.1d Built-in)
– Compiling module top_wrapper
** Error: (vlog-13069) ** while parsing file included at …/sim/testbench/testbench.sv(5)
** while parsing file included at …/sim/testbench/…/testbench/includes.sv(2)
** at …/sim/testbench/…/tests/define_pkg.sv(6): near “package”: syntax error, unexpected “SystemVerilog keyword ‘package’”.
– Importing package uvm_pkg (uvm-1.1d Built-in)
** while parsing file included at …/sim/testbench/…/testbench/includes.sv(4)
** at …/sim/testbench/…/agents/clock_reset_agent/sequence_lib/clock_reset_seq_pkg.sv(18): near “endpackage”: syntax error, unexpected “SystemVerilog keyword ‘endpackage’”.
** Error: ** while parsing file included at …/sim/testbench/testbench.sv(5)
** while parsing file included at …/sim/testbench/…/testbench/includes.sv(5)
** at …/sim/testbench/…/agents/clock_reset_agent/clock_reset_agent_pkg.sv(11): (vlog-13006) Could not find the package (clock_reset_seq_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
** while parsing file included at …/sim/testbench/…/agents/clock_reset_agent/clock_reset_agent_pkg.sv(16)
** at …\sim\testbench..\agents\clock_reset_agent\clock_reset_driver.sv(4): (vlog-13006) Could not find the package (define_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
** at …\sim\testbench..\agents\clock_reset_agent\clock_reset_driver.sv(104): (vlog-2730) Undefined variable: ‘N_CYCLES_HARD_RESET’.
** at …\sim\testbench..\agents\clock_reset_agent\clock_reset_driver.sv(104): (vlog-2730) Undefined variable: ‘CLK_PERIOD_NS’.
** at …\sim\testbench..\agents\clock_reset_agent\clock_reset_driver.sv(126): (vlog-2730) Undefined variable: ‘CLK_PERIOD_NS’.
** at …/sim/testbench/…/agents/clock_reset_agent/clock_reset_agent_pkg.sv(21): near “endpackage”: syntax error, unexpected “SystemVerilog keyword ‘endpackage’”.
** while parsing file included at …/sim/testbench/…/testbench/includes.sv(6)
** at …/sim/testbench/…/agents/clock_reset_agent/clock_reset_intf.sv(18): near “endinterface”: syntax error, unexpected “SystemVerilog keyword ‘endinterface’”.
** while parsing file included at …/sim/testbench/…/testbench/includes.sv(8)
** at …/sim/testbench/…/agents/dh_fpga_agent/sequence_lib/dh_fpga_seq_pkg.sv(18): near “endpackage”: syntax error, unexpected “SystemVerilog keyword ‘endpackage’”.
** while parsing file included at …/sim/testbench/…/testbench/includes.sv(9)
** at …/sim/testbench/…/agents/dh_fpga_agent/dh_fpga_agent_pkg.sv(11): (vlog-13006) Could not find the package (dh_fpga_seq_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
** while parsing file included at …/sim/testbench/…/agents/dh_fpga_agent/dh_fpga_agent_pkg.sv(16)
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_driver.sv(4): (vlog-13006) Could not find the package (define_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_driver.sv(91): (vlog-2730) Undefined variable: ‘N_CYCLES_SOFT_RESET’.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_driver.sv(91): (vlog-2730) Undefined variable: ‘CLK_PERIOD_NS’.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_driver.sv(105): near “end”: syntax error, unexpected end.
** while parsing file included at …/sim/testbench/…/agents/dh_fpga_agent/dh_fpga_agent_pkg.sv(17)
** while parsing macro expansion: ‘uvm_component_utils’ starting at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(9)
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(9): (vlog-2730) Undefined variable: ‘dh_fpga_monitor’.
** Warning: ** while parsing file included at …/sim/testbench/testbench.sv(5)
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(9): (vlog-2953) Incorrect usage of keyword ‘static’.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(9): near “function”: syntax error, unexpected function, expecting IDENTIFIER or TYPE_IDENTIFIER or NETTYPE_IDENTIFIER.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(9): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(24): Illegal declaration after the statement near line ‘13’. Declarations must precede statements. Look for stray semicolons.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(33): (vlog-2164) Class or package ‘dh_fpga_monitor’ not found.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(34): ‘super.new()’ call can be made only from within a class constructor.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(35): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(39): (vlog-2164) Class or package ‘dh_fpga_monitor’ not found.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(44): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(49): (vlog-2164) Class or package ‘dh_fpga_monitor’ not found.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(54): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(62): (vlog-2164) Class or package ‘dh_fpga_monitor’ not found.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(76): Illegal declaration after the statement near line ‘62’. Declarations must precede statements. Look for stray semicolons.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(115): near “end”: syntax error, unexpected end.
** while parsing file included at …/sim/testbench/…/agents/dh_fpga_agent/dh_fpga_agent_pkg.sv(18)
** while parsing macro expansion: ‘uvm_component_utils’ starting at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_sequencer.sv(9)
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_sequencer.sv(9): (vlog-2730) Undefined variable: ‘dh_fpga_sequencer’.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_sequencer.sv(9): Typedef ‘type_id’ multiply defined.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_sequencer.sv(9): ‘get_type’ already exists; must not be redefined as a function.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_sequencer.sv(9): (vlog-2953) Incorrect usage of keyword ‘static’.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_sequencer.sv(9): near “function”: syntax error, unexpected function, expecting IDENTIFIER or TYPE_IDENTIFIER or NETTYPE_IDENTIFIER.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_sequencer.sv(9): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_sequencer.sv(17): (vlog-2164) Class or package ‘dh_fpga_sequencer’ not found.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_sequencer.sv(18): ‘super.new()’ call can be made only from within a class constructor.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_sequencer.sv(19): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** while parsing file included at …/sim/testbench/…/agents/dh_fpga_agent/dh_fpga_agent_pkg.sv(19)
** while parsing macro expansion: ‘uvm_component_utils’ starting at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(10)
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(10): (vlog-2730) Undefined variable: ‘dh_fpga_agent’.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(10): Typedef ‘type_id’ multiply defined.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(10): ‘get_type’ already exists; must not be redefined as a function.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(10): (vlog-2953) Incorrect usage of keyword ‘static’.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(10): near “function”: syntax error, unexpected function, expecting IDENTIFIER or TYPE_IDENTIFIER or NETTYPE_IDENTIFIER.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(10): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** Error (suppressible): ** while parsing file included at …/sim/testbench/testbench.sv(5)
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_monitor.sv(21): (vlog-2388) ‘monitor_to_scoreboard_aport’ already declared in this scope (run_phase).
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(22): Illegal declaration after the statement near line ‘14’. Declarations must precede statements. Look for stray semicolons.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(30): Illegal declaration after the statement near line ‘22’. Declarations must precede statements. Look for stray semicolons.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(40): (vlog-2164) Class or package ‘dh_fpga_agent’ not found.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(41): ‘super.new()’ call can be made only from within a class constructor.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(42): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(47): (vlog-2164) Class or package ‘dh_fpga_agent’ not found.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(61): (vlog-2730) Undefined variable: ‘m_sequencer’.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(61): (vlog-2164) Class or package ‘dh_fpga_sequencer’ not found.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(61): near “::”: syntax error, unexpected ::, expecting ‘;’.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(69): (vlog-2730) Undefined variable: ‘m_monitor’.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(69): (vlog-2164) Class or package ‘dh_fpga_monitor’ not found.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(69): near “::”: syntax error, unexpected ::, expecting ‘;’.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(76): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(81): (vlog-2164) Class or package ‘dh_fpga_agent’ not found.
** at …\sim\testbench..\agents\dh_fpga_agent\dh_fpga_agent.sv(93): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** while parsing file included at …/sim/testbench/…/testbench/includes.sv(10)
** at …/sim/testbench/…/agents/dh_fpga_agent/dh_fpga_intf.sv(19): Illegal declaration after the statement near line ‘9’. Declarations must precede statements. Look for stray semicolons.
** while parsing file included at …/sim/testbench/…/testbench/includes.sv(12)
** while parsing file included at …/sim/testbench/…/agents/flash_agent/sequence_lib/flash_seq_pkg.sv(14)
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(7): Illegal declaration after the statement near line ‘7’. Declarations must precede statements. Look for stray semicolons.
** while parsing macro expansion: ‘uvm_object_utils’ starting at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(9)
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(9): (vlog-2730) Undefined variable: ‘flash_seq_item’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(9): Typedef ‘type_id’ multiply defined.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(9): ‘get_type’ already exists; must not be redefined as a function.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(9): (vlog-2953) Incorrect usage of keyword ‘static’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(9): near “function”: syntax error, unexpected function, expecting IDENTIFIER or TYPE_IDENTIFIER or NETTYPE_IDENTIFIER.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(9): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(9): near “;”: syntax error, unexpected ‘;’, expecting ‘(’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(9): (vlog-2730) Undefined variable: ‘tmp’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(9): (vlog-2730) Undefined variable: ‘name’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(9): Illegal declaration after the statement near line ‘9’. Declarations must precede statements. Look for stray semicolons.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(9): (vlog-2730) Undefined variable: ‘tmp_data__’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(9): near “end”: syntax error, unexpected end.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(25): Illegal declaration after the statement near line ‘11’. Declarations must precede statements. Look for stray semicolons.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(34): (vlog-2164) Class or package ‘flash_seq_item’ not found.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(35): ‘super.new()’ call can be made only from within a class constructor.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(36): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(40): (vlog-2164) Class or package ‘flash_seq_item’ not found.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(41): near “;”: syntax error, unexpected ‘;’, expecting ‘(’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(48): (vlog-2730) Undefined variable: ‘addr’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(49): (vlog-2730) Undefined variable: ‘wdata’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(50): (vlog-2730) Undefined variable: ‘en_write_n’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(51): (vlog-2730) Undefined variable: ‘en_cs_n’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(52): (vlog-2730) Undefined variable: ‘rdata’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(54): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(58): (vlog-2164) Class or package ‘flash_seq_item’ not found.
Break key hit
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(61): Illegal declaration after the statement near line ‘58’. Declarations must precede statements. Look for stray semicolons.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(67): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(71): (vlog-2164) Class or package ‘flash_seq_item’ not found.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_seq_item.sv(73): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** while parsing file included at …/sim/testbench/…/agents/flash_agent/sequence_lib/flash_seq_pkg.sv(15)
** while parsing macro expansion: ‘uvm_object_utils’ starting at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(14)
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(14): (vlog-2730) Undefined variable: ‘flash_base_seq’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(14): Typedef ‘type_id’ multiply defined.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(14): ‘get_type’ already exists; must not be redefined as a function.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(14): (vlog-2953) Incorrect usage of keyword ‘static’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(14): near “function”: syntax error, unexpected function, expecting IDENTIFIER or TYPE_IDENTIFIER or NETTYPE_IDENTIFIER.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(14): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(14): near “;”: syntax error, unexpected ‘;’, expecting ‘(’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(14): Typedef ‘local_type_’ multiply defined.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(14): Illegal declaration after the statement near line ‘14’. Declarations must precede statements. Look for stray semicolons.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(14): near “end”: syntax error, unexpected end.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(30): (vlog-2164) Class or package ‘flash_base_seq’ not found.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(31): ‘super.new()’ call can be made only from within a class constructor.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(32): near “endfunction”: syntax error, unexpected endfunction, expecting endtask.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(39): (vlog-2164) Class or package ‘flash_base_seq’ not found.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(43): near “;”: syntax error, unexpected ‘;’, expecting ‘(’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(47): near “;”: syntax error, unexpected ‘;’, expecting ‘(’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(57): Illegal declaration after the statement near line ‘47’. Declarations must precede statements. Look for stray semicolons.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(57): (vlog-2164) Class or package ‘flash_seq_item’ not found.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(58): (vlog-2730) Undefined variable: ‘rsq_item’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(58): (vlog-2164) Class or package ‘flash_seq_item’ not found.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(58): near “::”: syntax error, unexpected ::, expecting ‘;’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(78): (vlog-2730) Undefined variable: ‘memory’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(81): (vlog-2730) Undefined variable: ‘req_item’.
** at …\sim\testbench..\agents\flash_agent\sequence_lib\flash_base_seq.sv(91): (vlog-13163) End label ‘body’ does not match task name on line 55.
** at …/sim/testbench/…/agents/flash_agent/sequence_lib/flash_seq_pkg.sv(17): near “endpackage”: syntax error, unexpected “SystemVerilog keyword ‘endpackage’”.
SIGSEGV: segmentation violation
** Error: C:/questasim64_10.7c/win64/vlog failed.
Error in macro ./simTest.do line 36
while executing
“vlog -coveropt 3 +cover -work work -f simTest.f +define+UVM_NO_DPI +define+UVM_REG_DATA_WIDTH=32”
