Why the FATAL error
Hi all, I am a beginner in UVM and trying a simple code to randomize two variable but getting some unwanted errors.Any suggesting will be appreciated.
edaLink
//=========== code starts here ============//
`include "uvm_macros.svh"
package my_pkg;
//sequence_item class
class my_transaction extends uvm_sequence_item;
  `uvm_object_utils(my_transaction)
  rand logic [3:0] a;
  rand byte b;
  constraint c_a {a>5;a<15;}
  constraint c_b {b>0;b<10;}
//sequence class
class my_sequence extends uvm_sequence #(my_transaction);
  `uvm_object_utils(my_sequence)
  my_transaction req;
  task body();
    repeat(10) begin
      req=my_transaction::type_id::create("req");
      start_item(req);
      if (!req.randomize()) begin
        `uvm_fatal("MY_SEQUENCE", "Randomize failed.");
      $display("a=%0d b=%0d",req.a,req.b);
      finish_item(req);
class sequencer extends uvm_sequencer #(my_transaction);
  `uvm_component_utils(sequencer)
  function new(string name,uvm_component parent=null);
    super.new(name,parent);
class driver extends uvm_driver #(my_transaction);
  `uvm_component_utils(driver)
//test class
  `uvm_component_utils(my_test)
  my_sequence seq;
  sequencer ss;
  driver div;
    seq=my_sequence::type_id::create("seq");
    ss=sequencer::type_id::create("ss",this);
    div=driver::type_id::create("div",this);
    div.seq_item_port.connect(ss.seq_item_export);
    phase.raise_objection(this);
    seq.start(ss);
    phase.drop_objection(this);
endpackage : my_pkg
module tb();
  import my_pkg::*;
    run_test("my_test");
//================== END ==================//
In reply to designMaster:
Please use the SV code tags to make your code more readble.
In your code you do not define the type sequencer, i.e. there is no class defined like this
Actually I don’t need any manual sequencer that’s why have directly instantiated the sequencer by
uvm_sequencer #(my_transaction) sequencer;
You have a reference like this in your code:
sequencer ss;
If you want to use the type_idd create method you have to define a seperate class for your sequencer and to register this with the factory.
And you have some additional weaknesses in your code. See the corrected code here:
The main point is now you are missing a driver. You are creating currently 1 seq_item. Then your tesbench is stucking and stopping by a timeout.
Thanks for the correction you made.But I am getting fatal error while running the code.
The fatal is caused by a timeout:
UVM_FATAL /playground_lib/uvm-1.2/src/base/uvm_phase.svh(1491) @ 9200000000000: reporter [PH_TIMEOUT] Default timeout of 9200000000000 hit, indicating a probable testbench issue
As I said this timeout appears because of the missing driver. Your sequencer generates 1 transaction. But this transaction is not processed by the driver. The sequencer is waiting. The timeout stops the simulation.
Its not being cleaned even I added the driver.
In your driver you do not process the transaction. The run_phase is missing.
See a solution here:
I am really really helped by the solution you provide.Thank you very much.
