Why even use analysis_export?
Hi all ,
I was reading a paper by Clifford Cummings on analysis ports ( UVM Analysis Port Functionality and Using Transaction Copy Commands )
In that paper ( section 3.1.6 ) he talks about interchanging analysis_export with analysis_port .
He interchanges ::
(1) sub_Comp.ap.connect( parent_ap ) with Sub_Comp.ap.connect( parent_export ) // Sub-Component to Parent Analysis Port Connection
(2) sub_Comp1.ap.connect( sub_Comp2_export ) with sub_Comp1.ap.connect( sub_Comp2_ap ) // Port-to-export Connection
It works fine the transaction is ultimately transferred to all connected imps .
I had to go through the UVM Library to fully understand its working .
I see following advantages of analysis_ports over analysis_exports ::
AP :: analysis_port and AX :: analysis_export
(a) AP need not be connected ( min_size is 0 ) where AX needs to be connected ( min_size is 1 )
(b) AP can be connected to AX , AP , AIMP without even considering the hierarchy !! ( hence the txn occurs even after interchanging them )
(c) In both write() function within AP and AX class we call every imp connected to it .
 So why do we have analysis_export class ? Can't we simply replace it analysis_port ?
Thanks ,
ABD
In reply to ABD_91:
I believe you are misunderstanding a lot of things regarding ports/exports.
analysis_ports and analysis_export belonging together. On the same hierchy level you can only connects ports iwth exports. Only on different hierarchy levels you can connect ports with ports and exports with exports or imps. the ports are requring a method they are calling and the exports/imps have to provide this method. That is very simple but powerful.
After going through source code ( and even trying various codes ) I know one thing for certain , the port-to-port , port-to-export connection if not followed doesn’t have any consequences for analysis_port .
The txn object will still be transferred from starting port to the imp .
Here’s a snippet from uvm_port_base class ::
 // if we're an analysis port, allow connection to anywhere
    if (get_type_name() == "uvm_analysis_port")
       return 1;
Also when it comes to normal ( non analysis port classes ) if I use ::
sub_comp1.sub_comp2.port.connect ( sub_comp3.imp ) ;
// sub_comp2 is child of sub_comp1 . sub_comp1 and sub_comp3 are at same level of hierarchy .
I would still see the transaction being transferred from port to imp .
Here’s a link to a question I had posted regarding the same on accellera forum ::
In reply to ABD_91:
Look to the UVM Reference Manual. It says:
for
uvm_analysis_port: Broadcasts a value to all subscribers implementing a uvm_analysis_imp.
uvm_analysis_imp: Receives all transactions broadcasted by a uvm_analysis_port. It has to implement the write function.
uvm_analysis_export: Exports a lower-level uvm_analysis_imp to its parent.
