I am trying to debug a (SIGSEGV) Bad Handle or Reference error I am getting when I invoke p_sequencer.get_full_name() in task body() of a derived uvm_sequence.
The simulator I am using is Modelsim-Altera Starter Edition 10.1d.
Error message:
# ** Fatal : (SIGSEGV) Bad Handle or Reference
# Time : 0ps Iteration: 53 Process: /some_pkg::some_seq::some_seq_1::body/#FORK#282_dabd276 File: ./../../..//some_path/some_seq_lib.sv
# Fatal error in Function uvm_pkg/uvm_component::get_full_name at //engineering/asic/project_groups/ADE/UVM/references/uvm-1.1_RC5/uvm-1.1/src//base/uvm_component.svh line 1885
# HDL call sequence:
# Stopped at ./../../..//some_path/some_seq_lib.sv 287 Function uvm_pkg/uvm_component::get_full_name
Source Code:
class some_seq extends uvm_sequence;
`uvm_declare_p_sequencer(some_seqr)
task body();
some_item txn;
$display(p_sequencer.get_full_name()); // line 287
p_sequencer.get_port.get(txn); // line 288
class some_seqr extends uvm_sequencer;
some_item item;
this.get_port = new("get_port", this);
class some_env extends uvm_env;
some_seq seq;
some_agent agt;
some_mem_mdl sram;
agt = some_agent::type_id::create("agt",this);
seq = some_seq::type_id::create("seq");
super.connect_phase(phase);
this.seq.mem = sram;
this.seq.start(this.agt.sqr);
join_none
class some_test extends uvm_test;
some_env env;
function build_phase(uvm_phase phase);
this.env = some_env::type_id::create("env",this);
Any light into why I am getting this error is most welcome.
Martin
