Hi everyone,
Is there any concept of default sequencer(not the default sequence but sequencer) in UVM?
My assumption is that default sequences are relevant only when if there is any sequencer instantiated in TB and there is no such concept of default UVM sequencer.
Let me know if I am mistaking here.
Thanks in advance,
Chander
In reply to Chander_M:
You are defining a Default sequence always for the run_phase of a certain sequencer which can execute this sequence. This defines the relationship.
Note, it is not recommended to worrk with the default sequence.
Thanks, That indicates there is no concept of default sequencer and only instantiated sequencer can run any kind of sequence, be it default sequence.
Hi chr_sue
Is there any way we request UVM not to generate the default sequences for any sequencer in the TB?
Chander
If you do not define the default sequence there is also no corresponding sequencer.
Starting your sequences manually is the recommended and Default way.
I suppose by not including macro `uvm_update_sequence_lib_and_item in sequencer default sequences will not be created, right?
Chander
This macro has nothing to do with the default sequence.
Note this is a deprecated macro!
