Hi
I wanted to implement below
- Monitor interrupt event based on some address range ( from AXI monitor)
- Generate some events and this events will be observed in test/virtual sequence to trigger ISR.
I used below approach.
1.Used axi vip monitor callbacks to sample write/read address phase transaction.
2.send this to subscriber which decodes and generates events ( stores in even_pool)
3. wait for event in virtual sequence and trigger ISR.
Can some one suggest is this approach is fine or suggest is any best approach.
