Where to use ports and analysis ports
Hi everyone,
Can anyone help me that can we use analysis ports between the driver and sequencer instead of normal port and export?
In reply to sreekanth reddy undi:
the port-export connection is a 1 to 1 connection. The analysis_port-analysis_export connection is a 0 to many connection.
The methods used for transmitting data are different.
In addition, why did you want to change it? May you share the problem?
hi ,
we can use analysis port and analysis export for 1 to 1 connection,then can i use it in between driver and sequencer and is there any other specific reason of using normal ports?
This was a question asked in an interview.
The analysis_port/export provides only a non-blocking connection. This not adequate for the sequncer/driver connection and it does not have mnechanism to indicate a seq_item has been processed. This is what you need in the driver/serquencer connection.
I am unable to understand regarding this point you have said(it does not have mechanism to indicate a seq_item has been processed),it depends on the type of function or task you call from driver i.e if it is a pull mode.
if you use try_next_item function call from driver then it is also a non blocking call then?
The analysis_port/export does not have any blocking mechanism per definition. It is assigned to the anlysis path.
The port/export mechanism has blocking and non-blocking mechanism. If you are using there the non-blocking you have to run in a loop until you get the next item.
