Where can I get documetation of axi bus protocol?
I have to create verification enviorment for axi bus. Where can I get the spec or the protocil of the AXI bus?
http://infocenter.arm.com/help/topic/com.arm.doc.set.amba/index.html#specs
In reply to rajan passionate:
Documentation – Arm Developer
Where can I see the spec and the timing diagram?
In reply to saritr:
See this also, www.gstitt.ece.ufl.edu/courses/fall15/eel4720_5721/labs/refs/AXI4_specification.pdf
AMBA APB/AHB bus protocols will be nice to start with as they are less complex than AXI, See this GitHub for APB and AHB bus protocol UVM testbench, https://github.com/mayur13/UVMReference/tree/master/projects
