The task of run_phase is called in sqr of uvm and main method but where are all the other phase function called in Uvm ??
like build_phase();
connect_phase();
like build_phase();
connect_phase();
In reply to milin parekh:
The run_test task that you call from an initial block in your top-level testbench calls all the phases. I can show you n extremely simplified model of how it works (removing hierarchy, factory, and objections)
class component;
static component all_components[$];
function new;
all_components.push_back(this);
virtual function void build_phase();
virtual function void connect_phase();
virtual task run_phase;
virtual function void report_phase;
task automatic run_test;
foreach(all_components[comp]) all_components[comp].build_phase();
foreach(all_components[comp]) all_components[comp].connect_phase();
foreach(all_components[comp]) fork
int I = comp;
all_components[I].run_phase();
join_none
wait fork;
foreach(all_components[comp]) all_components[comp].report_phase();
endtask : run_test
Every class extended from uvm_component, like a sequencer, driver, monitor, etc. have these virtual phase methods declared in the base class. They are called regardless of whether you have declared overriding methods in your class or not.
Hi Dave,
Thanks for providing this simplifying example. What I have seen that m_run_phases task of -vm-hase is calling static method of get_common_domain and pushing a singleton Phase object to mailbox. And then there is a forever loop which is executing execute_phase method. How this execute_phase method is calling all children’s build_phase and then connect_phase and so on and so forth are called from this execute_phase method?
Yah that explanation was fine. But my doubt is other than build_phase and final_phase … like connect_phase must run in bottom up approach… so we should traverse foreach in reverse…?
In reply to Rozz:
You should not have code that depends on the order within a phase, other than the build_phase.
