Hi.
I got the uvm_root type when I try to print my test case as bewow.
I didn’t get it this situaltion, what am I suppoed to do to resolve unnamed problem?
If I want to connect between some sequence and my sequencer, then how am I suppoed to do ?
Can I just ignore about " uvm_root " ? to connect?
I used printing way as below.
virtual function void end_of_elaboration_phase(uvm_phase phase);
uvm_root uvm_top = uvm_root::get();
super.end_of_elaboration_phase(phase);
`uvm_info(get_type_name(), $sformatf("Printing environment settings: \n %0s", uvm_top.sprint()), UVM_LOW)
UVM_INFO plain_simple_write_test.sv(49) @ 0: uvm_test_top [plain_simple_write_test] Printing environment settings:
Name Type Size Value
<unnamed> uvm_root - @1040
uvm_test_top plain_simple_write_test - @2881
plain_environment plain_environment_c - @2971
plain_agent plain_agent_c - @3644
sequencer plain_sequencer - @3676
rsp_export uvm_analysis_export - @3733
seq_item_export uvm_seq_item_pull_imp - @4283
arbitration_queue array 0 -
lock_queue array 0 -
num_last_reqs integral 32 'd1
num_last_rsps integral 32 'd1
vijay_driver plain_driver - @4314
rsp_port uvm_analysis_port - @4413
seq_item_port uvm_seq_item_pull_port - @4364
virtual_sequencer plain_virtual_sequencer - @3002
rsp_export uvm_analysis_export - @3060
seq_item_export uvm_seq_item_pull_imp - @3610
