While I embark on UVM verification, I would like to know what to organize my code in package?
Are there any general guidelines as to what to put in a package?
In reply to verif_learner:
You are putting data of General interest in a package. And you should put all definions of an agent put into a package.
Thanks. I would assume the number of packages would be based on the distinct functionality that is composed in the packages?
I will use packages that reflect the hierarchy of my test environment. This allows ease of compilation as you compile from the bottom up and will only need to import one user package at the top level:
The top level will only need to import the test package.
You also can use packages such as
packages shares data and data is referenced within multiple modules, interfaces, components, sequences, programs, checkers etc.
