Hii,
I am beginner of the UVM. I am try to code a producer consumer transaction via the tlm fifo. But I am not get the expected value.So how to improve my code .
Tell your suggestion
And my code is below
`include "uvm_macros.svh"
class tlm_seq_item extends uvm_sequence_item;
rand bit a;
rand byte b;
rand int c;
`uvm_object_utils_begin(tlm_seq_item)
`uvm_field_int(a,UVM_ALL_ON)
`uvm_field_int(b,UVM_ALL_ON)
`uvm_field_int(c,UVM_ALL_ON)
`uvm_object_utils_end
function new(string name="tlm_seq_item");
class tlm_producer extends uvm_component;
`uvm_component_utils(tlm_producer)
uvm_blocking_put_port #(tlm_seq_item) my_put_port;
function new(string name="tlm_produce", uvm_component parent=null);
super.new(name,parent);
my_put_port=new("my_put_port",this);
for(int i=0;i<5;i++)
tlm_seq_item seq;
seq=tlm_seq_item::type_id::create("seq",this);
seq.randomize();
seq.print();
//$display("IT IS PRODUCER");
my_put_port.put(seq);
`uvm_info("SEND",$sformatf("the data ia i=%d %p",i,seq),UVM_LOW)
#10;
class tlm_consumer extends uvm_component;
`uvm_component_utils(tlm_consumer)
uvm_blocking_get_port #(tlm_seq_item) my_get_port;
function new(string name="tlm_consumer",uvm_component parent=null);
my_get_port=new("my_get_port",this);
tlm_seq_item seq;
my_get_port.get(seq);
`uvm_info("REC",$sformatf("recieved packet i=%0d %p",i,seq),UVM_LOW)
class tlm_env extends uvm_env;
`uvm_component_utils(tlm_env)
uvm_tlm_fifo #(tlm_seq_item) my_fifo;
tlm_producer producer;
tlm_consumer consumer;
function new (string name="tlm_env",uvm_component parent=null);
function void buid_phase(uvm_phase phase);
producer=tlm_producer::type_id::create("producer",this);
consumer=tlm_consumer::type_id::create("consumer",this);
//$display("builded or producer and consumer");
producer.my_put_port.connect(my_fifo.put_export);
consumer.my_get_port.connect(my_fifo.get_export);
phase.raise_objection(this);
#1000;
phase.drop_objection(this);
module top;
tlm_env env;
env=new();
$display("calling");
run_test();
$display("end calling");
