Hello
I have one question…
Q1) Are the registers accessible through one interface composed of one UVM_REG_BLOCK? or cna it consist of multiple UVM_REG_BLOCK?
Thanks in advance
Hello
Thanks in advance
In reply to suhyun:
You can build a hierarchy of UVM Reg blocks so at the top level there will be one interface. That assumes your design has a single top-level block of registers with one or more interfaces. But you could have independent reg blocks if your design has completely separate address spaces with separate sets of registers.
