What is difference between uvm_event_pool and uvm_event?
Hello,
I am new to UVM,
i had worked with uvm_event but not familiar with uvm_event_pool.
Please share some knowledge on uvm_event_pool and difference between them.
In reply to meet81193:
From the UVM source code
class uvm_pool #(type KEY=int, T=uvm_void) extends uvm_object;
 protected T pool[KEY];
class uvm_object_string_pool #(type T=uvm_object) extends uvm_pool #(string,T);
typedef uvm_object_string_pool #(uvm_event) uvm_event_pool;
A Pool is UVM’s way of parameterizing an associative array with a set of parameterized access methods. So uvm_event_pool is
event pool[string];
Thank you for your answer
