`include:
We have a uvm environment,we have a package file with in the package file we declare the all file like include "dut.sv",
include “driver.sv”, all components etc…
import:
with in the component we are write import package import pkg_1::; import uvm_pkg::;
Iam not understand what is the difference and what is the use of.
The include construct is used to include a file in just one place.
include is typically used to include .svh files when creating a package file. If one needs to reference a type or other definition, then ‘import’ is used to bring the definition into scope.
Why one shouldn’t use include, is because type definitions are scope specific. A type defined in two scopes using the same
include file are not recognised as being the same. If the type is defined in one place, inside a package, then it can be properly referenced by importing that package.
