What is the best way to implement a wait in a UVM sequence, for an internal DUT signal to assert before proceeding to send sequence items to the driver?
My coworker is trying this approach:
In the TB top module, instancing an interface with a single logic signal.
Doing a continuous assign of the signal in the interface to the internal DUT signal (Using the full hierarchical path to the internal DUT signal)
i.e. assign if.trigger_signal = tb_top.DUT.internal_signal
Doing a UVM config_db “set” to pass the virtual interface.
In the Sequence, task body(), do a UVM config_db “get” to get a handle to the interface.
Do a @(vif.trigger_signal) to block until the internal DUT signal asserts.
We’re having trouble getting this approach to work, and wanted to know if there is any issue with this approach itself?
Is there a better approach?
