interface file : -
interface ahb_intf(input logic HCLK);
logic HRESETn;
logic HREADY;
logic [1:0] HTRANS;
logic [2:0] HBURST;
logic [2:0] HSIZE;
logic HWRITE;
logic [31:0] HADDR;
logic [31:0] HWDATA;
logic [31:0] HRDATA;
logic [1:0] HRESP;
clocking mdrv_cb@(posedge HCLK);
default input #1 output #0;
output HTRANS;
output HBURST;
output HSIZE;
output HWRITE;
output HADDR;
output HWDATA;
input HREADY;
input negedge HRESP;
input HRDATA;
endclocking
clocking mmon_cb@(posedge HCLK);
input HRESETn;
input HREADY;
input HTRANS;
input HBURST;
input HSIZE;
input HWRITE;
input HADDR;
input HWDATA;
input HREADY;
input HRESP;
input HRDATA;
endclocking
endinterface
Define file : -
typedef enum bit[1:0] {IDLE, BUSY, NONSEQ, SEQ} transfer_t;
typedef enum bit {READ, WRITE} rw_t;
typedef enum bit [2:0] {SINGLE, INCR, WRAP4, INCR4, WRAP8, INCR8, WRAP16, INCR16} burst_t;
typedef enum bit [2:0] {BYTE, HALFWORD, WORD, WORDx2, WORDx4, WORDx8, WORDx16, WORDx32} size_t;
typedef enum bit [1:0] {OKAY, ERROR, RETRY, SPLIT} resp_t;
slave xtn file : -
class ahb_sxtn extends uvm_sequence_item;
bit reset;
bit [31:0] address[$];
bit [31:0] write_data[$];
transfer_t trans_type;
burst_t burst_mode;
size_t trans_size;
rw_t read_write;
bit [31:0] read_data[$];
rand resp_t response;
rand bit ready[];
slave monitor code : -
task ahb_smonitor::monitor();
begin: mon1
xtn = ahb_sxtn::type_id::create("xtn");
do
begin: collect
$cast(xtn.trans_type, vif.mmon_cb.HTRANS); // error
$cast(xtn.burst_mode, vif.mmon_cb.HBURST); // error
$cast(xtn.trans_size, vif.mmon_cb.HSIZE); // error
$cast(xtn.read_write, vif.mmon_cb.HWRITE); // error
$cast(xtn.response, vif.mmon_cb.HRESP); // error
xtn.address.push_back(vif.mmon_cb.HADDR); // error
if((xtn.trans_type == IDLE) && (vif.HRESETn == 1))
@(vif.mmon_cb);
`uvm_info(get_type_name(), "IDLE Transaction Detected..", UVM_MEDIUM)
while executing the code I am getting the following error : -
# ** Error: (vsim-3971) $cast to type 'enum bit[1:0] ahb_spkg::transfer_t' from 'reg[1:0]' failed in file /work/lk/projects/sim../../env/ahb/ahb_slv_agent/ahb_smonitor.svh at line 84.
** Error: (vsim-3971) $cast to type 'enum bit[2:0] ahb_spkg::burst_t' from 'reg[2:0]' failed in file /work/lk/projects/sim/../../env/ahb/ahb_slv_agent/ahb_smonitor.svh at line 85.
I am using Questa sim simulator
can anyone tell me the problem ?
