Hello,
I am trying to use virtual sequencers, but in the assignment of the handles in the virtual sequencer class to the actual sequencers, I keep getting this error:
Loading work.tinyalu(rtl)#1
** Error: (vsim-3567) tb_classes/env_w_agent.svh(36): No field named ‘sequencer_h’.
Time: 0 ns Iteration: 0 Region: /tinyalu_pkg File: tinyalu_pkg.sv
** Error: (vsim-3567) tb_classes/env_w_agent.svh(37): No field named ‘sequencer_h’.
** Error: (vsim-7065) tb_classes/env_w_agent.svh(37): Illegal assignment to type ‘reg’ from type ‘class work.tinyalu_pkg::sequencer’: Cannot assign an unpacked type to a packed type.
** Error: (vsim-7065) tb_classes/env_w_agent.svh(36): Illegal assignment to type ‘reg’ from type ‘class work.tinyalu_pkg::sequencer’: Cannot assign an unpacked type to a packed type.
The problem is that the assignment of
v_sqr.add_sequencer.sequencer_h = add_agent.sequencer_h;
v_sqr.sub_sequencer.sequencer_h = sub_agent.sequencer_h;
in the env_w_agent.svh file, is somehow an “unpacked-to-packed” assignment…?
I am quite confused as to why I am getting this error and cannot find any help from previous posts…
Any help would be greatly appreciated, thanks!
Code:
class env extends uvm_env;
`uvm_component_utils(env);
virtual_sequencer v_sqr;
tinyalu_agent #("abfm") add_agent;
tinyalu_agent #("sbfm") sub_agent;
super.new(name,parent);
endfunction : new
add_agent = tinyalu_agent#("abfm")::type_id::create("add_agent",this);
sub_agent = tinyalu_agent#("sbfm")::type_id::create("sub_agent",this);
v_sqr = virtual_sequencer::type_id::create("m_v_sqr", this);
endfunction : build_phase
class tinyalu_agent #(string BFM_NAME="bfm") extends uvm_agent;
`uvm_component_param_utils(tinyalu_agent#(BFM_NAME))
driver #(BFM_NAME) driver_h;
sequencer sequencer_h;
endfunction : new
sequencer_h = sequencer::type_id::create("sequencer_h",this);
driver_h = driver#(BFM_NAME)::type_id::create("driver_h",this);
driver_h.seq_item_port.connect(sequencer_h.seq_item_export);
endfunction : connect_phase
endclass : tinyalu_agent
class virtual_sequencer extends uvm_sequencer #(uvm_sequence_item);
`uvm_component_utils(virtual_sequencer)
sequencer add_sequencer;
sequencer sub_sequencer;
function new(string name = "virtual_sequencer", uvm_component parent = null);
endclass: virtual_sequencer
class sequencer extends uvm_sequencer #(sequence_item);
`uvm_component_utils(sequencer)
// Standard UVM Methods:
function new(string name="sequencer", uvm_component parent = null);
endclass: sequencer
virtual class tinyalu_base_test extends uvm_test;
env env_h;
env_h = env::type_id::create("env_h",this);
endfunction : new
class add_test extends tinyalu_base_test;
`uvm_component_utils(add_test);
add_sequence add_seq;
add_seq = new("add_seq");
phase.raise_objection(this);
add_seq.start(null);
phase.drop_objection(this);
endtask : run_phase
endfunction : new
package tinyalu_pkg;
`include "uvm_macros.svh"
`include "sequence_item.svh"
`include "abstract.svh"
`include "sequencer.svh"
`include "virtual_sequencer.svh"
`include "add_sequence.svh"
`include "driver.svh"
`include "tinyalu_agent.svh"
`include "env_w_agent.svh"
`include "tinyalu_base_test.svh"
`include "add_test.svh"
endpackage : tinyalu_pkg
