arlin
July 12, 2017, 7:04am
1
Hi All,
Two different agents are merged into single environment.
My doubt is regarding virtual sequencer.
In test,
Inside phase raise and drop objection, virtual_sequence.start(top_env.virtual_sequencer) is given but the error is that “virtual_sequencer is missing in top_env”.Please help me with the hierarchy of the same.
In top_env,two agents are declared. Where do I need to declare sequencers/virtual sequencer.
In reply to ajp :
You should instantiate your virtual sequencer in top_env and you should connect your actual sequencers to the sequencers in virtual sequencer.
In reply to ajp :
You do not Need a virtual sequencer at all.
arlin
July 12, 2017, 11:36am
5
In reply to chr_sue :
How to start the sequences of master and slave without virtual sequencer.
I am facing the error as “sequencer has been not supplied to start the sequence”.
Thanks in advance.
In reply to ajp :
You need only the handles to your agent sequencers in the virtual sequence.
Then you can start the virtual sequence like this:
vseq.start(null);
arlin
July 13, 2017, 8:54am
7
to chr_sue :
Okay…
Its working without virtual sequencer but I am not able to drive the sequence of both the agents.
May I know the corrective step to proceed with the sequences.
In reply to ajp :
Could you please explain what does it mean: it is working?
See a virtual sequence example below:
class example_top_base_seq extends uvm_sequence #(uvm_sequence_item);
`uvm_object_utils(example_top_base_seq)
example_top_config cfg;
apb_sequencer apb_sequencer_i;
spi_sequencer spi_sequencer_i;
extern function new(string name = "example_top_base_seq");
extern task body();
// constraints
endclass : example_top_base_seq
// example_top_base_seq implementation
function example_top_base_seq::new(string name = "example_top_base_seq");
endfunction : new
task example_top_base_seq::body();
if (!uvm_config_db #(apb_sequencer)::get(null, get_full_name(), "apb_sequencer", apb_sequencer_i))
`uvm_error(get_type_name(), "Config Error uvm_config_db #(apb_sequencer)::get cannot find sequencer")
if (!uvm_config_db #(spi_sequencer)::get(null, get_full_name(), "spi_sequencer", spi_sequencer_i))
`uvm_error(get_type_name(), "Config Error uvm_config_db #(spi_sequencer)::get cannot find sequencer")
endtask: body
// Sequence : example_top_default_seq
// Author : <author> Tel: <phone> Email: <email>
// Using : <list of sub-sequences used by this sequences>
// Description : Sequence generating 1 item;
class example_top_default_seq extends example_top_base_seq;
`uvm_object_utils(example_top_default_seq)
// UVC sequences
apb_default_seq apb_seq;
spi_default_seq spi_seq;
extern function new(string name = "example_top_default_seq");
extern task body();
endclass : example_top_default_seq
// example_top_default_seq implementation
function example_top_default_seq::new(string name = "example_top_default_seq");
endfunction : new
task example_top_default_seq::body();
super.body();
apb_seq = apb_default_seq::type_id::create("apb_seq");
spi_seq = spi_default_seq::type_id::create("spi_seq");
`uvm_info(get_type_name(),"default sequence starting", UVM_MEDIUM)
repeat(10) begin
`uvm_info(get_type_name(),"apb sequence starting", UVM_MEDIUM)
void'(apb_seq.randomize());
apb_seq.start(apb_sequencer_i);
`uvm_info(get_type_name(),"spi sequence starting", UVM_MEDIUM)
void'(spi_seq.randomize());
spi_seq.start(spi_sequencer_i);
`uvm_info(get_type_name(),"default sequence completed",UVM_MEDIUM)
endtask : body
arlin
July 14, 2017, 4:43am
9
Hi…
Thank you for your response.
I tried with above mentioned solution and the error which I am facing is as "neither the item’s sequencer nor dedicated sequencer has been supplied to start the item in master_sequence/slave_sequence "
