Hi All,
I have;
interface.svh
main_test.svh
param_pkg.sv
Interface code is as follows;
interface intf #(int DATA=32) ();
endinterface
Main testcase code is as follows;
class main_test extends uvm_test;
typedef virtual intf#(DATA) i_intf;
if (!uvm_config_db #(i_intf) ::get(this, …))
`uvm_errors(…)
Param_pkg is as follows;
package test_param;
localparam DATA=32;
endpackage
Now, when running the testcase with Questa 10.5, it gives an error;
Virtual Interface Resolution Cannot Find a Matching Instance for ‘virtual intf #32’
I have gone through the similar queries from this forum and I have tried;
- Replacing DATA as 32 in main_test, but still the error remains same.
- Replacing code in main_test;
if (!uvm_config_db #(i_intf) ::get(this, …)) with
if (!uvm_config_db #(i_intf #(32) ) ::get(this, …))
but I could not find the solution.
May I know what changes I need to do to fix this error?
