As in my testbench env i am making all warnings into errorduring compile, I am passing -warning error in mti_simulator.py file , but after this I am facing the below error, any idea about this ? I dont see anything wrong in the below code
@(vif.monitor_cb);
| ** Error (suppressible): (vlog-13262) A virtual interface element is not allowed in a sensitivity list.
task etm_waypoint_monitor::monitor_viewinst();
forever
@(vif.monitor_cb);
if (vif.monitor_cb.etm_enabled)
trace_session_cycle_count++;
// If Viewinst is high
if (vif.monitor_cb.viewinst)
viewinst_cycle_count++;
l get this error in questa only if the ‘pedanticerrors’ flag is set
Dave’s code will also flag this if compiled with this flag.
However, I still think it’s a bug in Questa
The Questa help for this error cites
“LRM Section 25.9: ‘they [virtual interface elements] cannot be used in continuous assignments or sensitivity lists’.”
as the reason for enforcing this check. However, in that section it then goes on to say that the way to do it properly is via a clocking block!
I pulled the example from the LRM section almost verbatim (with one tweak to actually make it valid)
This also fails in Questa but again only with the ‘pedanticerror’ flag
To be fair to Questa it was the only one to actually compile and run the example in its entirety at all!
To reiterate Dave a little working example goes a long way. However, I think you may have inspired this helpful post from him a few days later.
