UVM_RAL Frontdoor write & write_reg
hello everyone,
I am trying register model front door access. when i use write & write_reg methods to write in to registers, simulation gets hangs. i am not able find the problem. Here is the whole code i have written
//sequence
class reg_seq extends uvm_sequence;
//instance of reg block
apb_reg_block apb_rb;
enfunction
apb_rb.ld_reg.set(32'hb);
data= apb_rb.ld_reg.get();
apb_rb.ld_reg.write(status,data,.parent(this));
/////////////==========virtual sequence class=========///////////////
class vir_reg_sequence extends virtual_sequence;
`uvm_object_utils(vir_reg_sequence)
//*********************constructor***********************
function  new (string name="vir_reg_sequence");
endfunction:new
//*********************body method***********************
task body();
super.body();
reg_seq=reg_sequence::type_id::create("reg_sequence");
wreg_seq=wdog_read_default_values::type_id::create("wdog_read_default_values");
		`uvm_info("VIRTUAL SEQUENCE T.C. 10","///////In Body of Virtual Sequence T.C. 5 ////////",UVM_MEDIUM)
		reg_seq.start(vir_seqrh.master_seqrh[0]);
		wreg_seq.start(vir_seqrh.slave_seqrh[0]);
	join
////////================adapter class=================////////
class reg_adapter extends uvm_reg_adapter;
	`uvm_object_utils(reg_adapter)
	function new(string name = "reg_adapter");
		supports_byte_enable =0;
		provides_responses = 1;
	virtual function uvm_sequence_item reg2bus(const ref uvm_reg_bus_op rw);
		master_trans trans = master_trans::type_id::create("trans");
		if(rw.kind == UVM_WRITE) begin
		trans.pwrite = (rw.kind == UVM_WRITE) ? UVM_WRITE: UVM_READ;
		trans.paddr = rw.addr;
		trans.pwdata = rw.data;
		trans.penable=1'b1;
		trans.presetn=1'b1;
		trans.psel=1'b1;
		`uvm_info("REG2BUS_W",$sformatf("printing from the adapter reg2bus write access \n %s",trans.sprint()),UVM_LOW)
		else if(rw.kind == UVM_READ) begin
			trans.pwrite=1'b0;
			trans.paddr=rw.addr;
			`uvm_info("REG2BUS_R",$sformatf("printing from the adapter reg2bus read access \n %s",trans.sprint()),UVM_LOW)
		return trans;
	virtual function void bus2reg(uvm_sequence_item bus_item,ref uvm_reg_bus_op rw);
		master_trans trans;
		if(!$cast(trans,bus_item)) begin
			`uvm_fatal("APB_ADAPTER", "cast failed in the adapter" );
			return;
			rw.kind = trans.pwrite ? UVM_WRITE :UVM_READ;
				rw.addr = trans.paddr;
				rw.data = trans.pwdata;
				`uvm_info("BUS2REG_W",$sformatf("printing from the adapter bus2reg write access \n %s",trans.sprint()),UVM_LOW)
				rw.data = trans.prdata;
				`uvm_info("BUS2REG_W",$sformatf("printing from the adapter bus2reg read access \n %s",trans.sprint()),UVM_LOW)
				rw.status = UVM_IS_OK;
///////////=============register class==============///////////
class load_register extends uvm_reg;
	`uvm_object_utils(load_register)
	rand uvm_reg_field ld_reg;
	  function new(string name="load_register");
   		super.new(name,32,UVM_NO_COVERAGE);
	          ld_reg = uvm_reg_field::type_id::create("ld_reg");
		          ld_reg.configure(this,32,0,"RW",0,'hFFFFFFFF,1,1,0);
/////////////////////============register block===========////////////////
class apb_reg_block extends uvm_reg_block;
	`uvm_object_utils(apb_reg_block)
	rand load_register ld_reg;
	uvm_reg_map apb_map;
	function new(string name = "apb_reg_block");
		super.new(name,UVM_NO_COVERAGE);
		ld_reg =load_register::type_id::create("load_register");
		ld_reg.configure(this,null,"");
		ld_reg.build();
		ld_reg.add_hdl_path_slice("load_register",0,32);
		apb_map = create_map("apb_map",'h0,4,UVM_LITTLE_ENDIAN);
		default_map = apb_map;
		apb_map.add_reg(ld_reg,'h0000,"RW");
		add_hdl_path("top.DUT.u_apb_watchdog_frc","RTL");
		lock_model();
///////////==========environment==========//////
class tb extends uvm_env;
	`uvm_component_utils(tb)
//adapter instance
reg_adapter adapter_h;
//predictor
uvm_reg_predictor#(master_trans) predictor_h;
//*******************************Build_phase*******************************
function void env ::build_phase(uvm_phase phase);
	//predictor creation
	predictor_h = uvm_reg_predictor#(master_trans)::type_id::create("predictor_h",this);
	//Adapter creation
	adapter_h = reg_adapter::type_id::create("adapter_h",this);
endfunction:build_phase
	if(env_cfg.apb_rb.get_parent== null) begin
		env_cfg.apb_rb.apb_map.set_sequencer(.sequencer(master_top.agent_h[0].seqr_h), .adapter(adapter_h));
		predictor_h.map = env_cfg.apb_rb.apb_map;
		predictor_h.adapter = adapter_h;
		env_cfg.apb_rb.apb_map.set_auto_predict(0);
		master_top.agent_h[0].monitor_h.monport.connect(predictor_h.bus_in);
///////////==============test============////////
class test_reg_seq extends test;
	`uvm_component_utils(test_reg_seq )
//Declaring handle of virtual default sequence
vir_reg_sequence vir_reg_seq;
//*********************************Run_phase***************************
task test_reg_seq::run_phase(uvm_phase phase);
	phase.raise_objection(this);
      		super.run_phase(phase);
		//Creating handle of virtual sequence
		vir_reg_seq=vir_reg_sequence::type_id::create("rg_seq_h");
		//rg_seq_h.model=reg_block_h;
		vir_reg_seq.start(tb_h.vir_seqr_tb);
	phase.drop_objection(this);
In reply to abhishek403:
Where do you get the handl of apb_rb in req_seq?
i am getting this handle from uvm_reg_block.
But I do not see, where you are doing this.
//This is for APB_load_register
	ld_reg.configure(this);//,null,"");
	ld_reg.build();
//creating address maps for the declared registers
	lock_model();
This was not my question. I have seen your regmodel. What I mean is you have to make an assignment to the regmodel handle in your sequence. Where ist it?
It is somthing like this (what you have commented out:
Sorry for the trouble, I have not connected it in the sequence, I did it in the test class
But you did not show it in your code. It should look like
vir_reg_seq.rg_seq.apb_rb = <reg_block_name in test>;
Or did you do this in your class test which is not shown.
Thanks a lot it worked for me.
I assigned this handle in reg_seq and it worked fine.
apb_rb.ld_reg.read(status,value,.parent(this));
But when i’m use this read method simulation gets hang only for read not for write operation and I found that the problem is in my monitor(forever loop). and I didn’t understood one thing is that it is not coming out from the loop, is there any problem in the predictor monitor connection. if you could help me from this it will be really helpful, Here is my monitor logic
class master_monitor extends uvm_monitor;
`uvm_component_utils(master_monitor)
//transaction handle
master_trans mon_txn
uvm_analysis_port #(master_trans) monport;
//constructor
//build_phase
mon_txn = master_trans::type_id::create("mon_txn");
//run_phase
task master_monitor::run_phase(uvm_phase phase);
if(vif.apb_monitor_cb.penable) begin
@(vif.apb_monitor_cb);
mon_txn.paddr= vif.apb_monitor_cb.paddr;
mon_txn.pwdata= vif.apb_monitor_cb.pwdata;
monport.write(mon_txn);
Fine.
With respect to your monitor. Do you see
vif.apb_monitor_cb.penable = 1'b1
and the edge of
vif.apb_monitor_cb
