Uvm_object requires default value for name?
It seems to me that any uvm_object needs a default value for its constructor name argument. Why is this? I guess it must be somewhere in the factory as the create is passed the argument.
And why is this different for uvm_component?
In reply to NiLu:
Any uvm_component as well as a uvm_object needs a default value for the argument name. But the name might be an empty string like this “”.
I thought (by trial) - but have to check - uvm_component doesn’t need a default value.
In the mean time after some more investigation I think to realize that the default value is required because the factory create method actually calls the new method without arguments followed by set_name. I wonder why it was done that way…
In reply to NiLu:
Classes derived uvm_component must not have a default name. The is because the name is used to build a component hierarchy tree and a component needs a unique non-null name for each level of the hierarchy.
UVM 1.2 is now requiring that the factory pass a name to the object, so a default is no longer required. See Mandatory uvm_object Constructors
