UVM_EXPORT Class Confusion
I have a question about uvm_*_export classes .
I Observe that each *_export class overrides a subset of the method in uvm_tlm_if_base .
I am not sure why is it so ?
Port N Imps override them since they are used during actual method calls
whereas a user Never calls method for an export
Any clarification would be helpful .
In reply to MICRO_91:
The UVM TLM code is vastly overcomplicated by the fact that it was written before SV had multiple interface inheritance. You get an runtime error if you try calling a method that has not been overridden. If this was recoded using the current standard, you would be able to get a compiler error.
