My agent needs to drive a “done” signal when any some input is received on any one of the two input interfaces. I am using analysis ports to get input transactions and pushing that data on a queue for both cases. I tried to use the event data type but am not able to properly drive the done signal.
input1_data_type _input1[$];
input2_data_type _input2[$];
event input1_received;
event input2_received;
virtual function void write_input1 (input1_data_type _trans);
_input1.push_back(_trans);
->input1_received;
endfunction: write_input1
virtual function void write_input2 (input2_data_type _trans);
_input2.push_back(_trans);
->input2_received;
endfunction: write_input2
//Not showing the build_phase where I retrieve the interfaces and connect the analysis ports.
virtual task run_phase (uvm_phase phase);
super.run_phase(phase);
//Other tasks
drive_done();
join_none
endtask: run_phase
virtual task drive_done();
@(input1_received.triggered || input2_received.triggered)
output_interface_vif.done <= 1'b1;
The above code does not drive the done back to 0 at the next clock. Note I am not able to compile with “##1” as I get the error:
Cycle delay operator requires a default clocking to be specified for
module/interface/program ‘vcs_paramclassrepository’.
The clk and reset are not driven by this agent and I think I can’t specify the timeunit(which I think is what the error is indicating) in this class as it is central to the whole testbench and is likely to change.
I also tried the following but it is not driving interface at all even though I can see transactions being pushed on the queue.
@(output_interface_vif.monitor.clk);
if(input1_received.triggered || input2_received.triggered)
else
output_interface_vif.done <= 1'b0;
Can someone suggest a good way to make this work?
