questasim command to run below program:
//vlog -sv +incdir+$UVM_HOME/src $UVM_HOME/src/uvm.sv $UVM_HOME/src/dpi/uvm_dpi.cc uvm_object_cfg_example.sv
//vsim -c tb_top -l simv.log -do “run -all;quit” +UVM_TESTNAME=test
Program:
`include “uvm_macros.svh”
class address_map_info extends uvm_object;
rand int min_addr;
rand int max_addr;
function new(string name = “address_map_info”);
uvm_object_utils_begin(address_map_info)
uvm_field_int(min_addr, UVM_DEFAULT)
uvm_field_int(max_addr, UVM_DEFAULT)
uvm_object_utils_end
endclass : address_map_info
class test extends uvm_test;
`uvm_component_utils(test)
address_map_info cfg;
function new(string name=“test”,uvm_component parent);
super.new(name,parent);
cfg = address_map_info::type_id::create(“cfg”, this);
uvm_config_db#(int)::set(this,“.cfg",“min_addr”,25);
uvm_config_db#(int)::set(this,".cfg”,“max_addr”,30);
phase.phase_done.set_drain_time(this, 50);
phase.raise_objection(this, “Starting run phase - raising objection”);
#2000;
phase.drop_objection(this, “Stopping run phase through drop_objection”);
#5;
uvm_info("TEST",$sformatf("::min_addr %0d max_addr %0d",cfg.min_addr,cfg.max_addr),UVM_NONE) cfg.randomize(); #5;
uvm_info(“TEST”,$sformatf(“::min_addr %0d max_addr %0d”,cfg.min_addr,cfg.max_addr),UVM_NONE)
join
module tb_top;
run_test();
Output:
UVM_INFO @ 0: reporter [RNTST] Running test test…
UVM_INFO xyz(48) @ 5: uvm_test_top [TEST] ::min_addr 0 max_addr 0
UVM_INFO xyz(51) @ 10: uvm_test_top [TEST] ::min_addr 621151839 max_addr -460094641
address_map_info is typedef of uvm_object. Using set (of uvm_config_db) method it sets value of two integers min_addr,max_addr. When these two variables are displayed in run_phase, values of these two variables after randomizing looks ok but, values of these two variables are unlikely zero after delay of #5 instead of 25,30.
I dont understand why does this happen?
Can anybody have fix in this code,It will really helpful for me?
Urvish
