Uvm_config_db - virtual interface
Hello all,
What is the reason we use “virtual” word when send the interfaces from test bench to UVM enviroment?
module x_top;
 interface x_if();
 logic data, clock, reset;
 endinterface: x_if
x_if x_if_inst;
uvm_config_db#(virtual x_if)::set(uvm_root::get(), "*", "x_vif", x_if_inst);
run_test();
Thanks !
In reply to mago1991:
The use of a virtual interface is a core concept in SystemVerilog that connects a class based environment to an instance based environment. I recommend you review the UVM Basics course to better understand this concept.
