I just used the following code and met with a compile error
class cfg0 extends uvm_object;
class C extends uvm_component;
cfg0 cfg0;
if(!uvm_config_db #(cfg0)::get(this, "", "cfg0", cfg0)
$display("ERROR");
The error message is:
Non-constant expression. The following expression should e a constant.
I doubt whether the error is due to name of class cfg0 which is same with object name.
I tried to change the “class cfg0” to “class cfg1”. It compile ok.
Can anyone explain this?
Thanks.
In reply to dmq0420:
Exactly, the type name and class object name must not have same name for setting/retrieving from config db.
In reply to mitesh.patel:
Could you elaborate why they should not have the same name?
Your problem is here:
uvm_config_db #(<insert the class name here>)::get(this, "", "cfg0", cfg0)
From my view, your code is same with mine.
Yours:
Mine:
I was reviewing you code on top. I see cfg0 is your class name. But I do not see an object of your class cfg0. You can only pass an object to the config_db.
The it has to be
if(!uvm_config_db #(cfg0)::get(this, "", "cfg0", <insert the object name of class cfg0 here>)
Here, config db needs class type and class object for successful get as follow:
uvm_config_db #(<insert the class name here>)::get(this, "", "<insert string keyword here>", <insert an object name of the class here>)
And as per oops concept class object name must not be as same as the class name.
I’m guessing your code is actually
cfg0 cfg0;
$display("ERROR");
By using the same name of the class type as the class variable, you are hiding the class type from further use in the class c. What you need is a different name.
cfg0 cfg0_h;
if(!uvm_config_db #(cfg0)::get(this, "", "cfg0_h", cfg0_h)
$display("ERROR");
Thanks Dave. Your code is exactly what I have.
I agree I’m hiding the class type. But I don’t know why I can’t use the same name for class type and object name. Actually I can’t find any description in the IEEE SystemVerilog standard about this.
You certainly can use the same name for two different identifiers as long as they are in different local scopes. (Section 3.13). But the search rules for referencing an identifier within a scope (Section 23.9) says to pick up the most locally nested identifier name first. That’s what we mean by hiding the name.
If the class cfg0 was declared in a package, you could work around this by prefixing the package name.
package P1;
endpackage
package P2;
import P1::*;
cfg0 cfg0;
if(!uvm_config_db #(P1::cfg0)::get(this, "", "cfg0", cfg0)
$display("ERROR");
Thanks Dave. It did fix my issue.
