iam getting the warning as body definition undefined if use `uvm_do_with macro and if i call built in methods like create,get_next_item,there will be no warning.
UVM_WARNING @ 0: uvm_test_top.e.a.ms@@seq.req [uvm_sequence_base] Body definition undefined
-----sequence code------
class wr_seq extends uvm_sequence#(seq_item);
`uvm_object_utils(wr_seq)
function new(string name=“wr_seq”);
task body();
repeat(10)
seq_item req;
`uvm_do_with(req,{w==1;})
/* req=seq_item::type_id::create(“req”);
wait_for_grant();
if(req.randomize()with{w==1;})
send_request(req);
wait_for_item_done();*/
//end
The warning message you are getting only happens when there is no body() task defined. The contents of the body() task should not change the base behavior.
Since this isn’t a complete set of code, it’s difficult to determine if there are other issues that may generate this warning. Are you perhaps calling ‘super.body()’ somewhere?
