When I use the automation of register model by register assistant, in the video, it use the command ‘vreguvm - gui’ to translate the .csv file to register package. But When I input this command, it reminds me ‘command not found’.
what’s the reason of that? The version I use is 10.2c_2. Do I need to install some package? If need, please tell me. I will ask the CAD administrator in my company to install it.
And where can I get the csv templates mentioned in the video?
Usual reason for ‘command not found’ is that your $path env variable is not set properly. Check on the same.
CAD team would be able to solve this issue quickly.
I used register assistant tool some time back, and I remember that the tool executable name is ‘regassist’. Check on the same too. CSV template should be available in the labs/examples directory in the tool installation.
The $path env should be right. Because I could normal use the other questa command.
For the executable name of regassist, I try this command. But also dosen’t work.
and for the CSV template, also it’s not in the tool installation.
For any tool specific issues, it is highly recommended that you contact your local support engineer. They would be able to provide you the personalized assistance you require.
The Questasim Register Assistant is a separate installation package that needs to be downloaded and installed as part of the Questasim installation. Most customers choose not to install it as they don’t use it. The installation directory is $QUESTA_INSTALL_DIR/RUVM_x.x. You will need to download it from SupportNet if you don’t have it installed, and add that directory to your path. The Questasim installation documentation contains all this information.
