Hello,
Recently I started working on UVM RAL, there I was trying to write to some of register from testcase without using any sequence and I am facing the error as described below:
Testcase:
env_obj.regmodel.reg1.write(status,32’h0000_9000);
NOTE: Reg_model is instantiated, build and locked in ENV.
The error I am getting is:
Illegal usage of class method. Class methods can’t be used in current context.
So my doubt is the methods can be used from sequences, if not why I am facing the error.
Thank you.
Asha
