There are two different agents accessing common RAL but addressing is different for registers in memory.Each memory location is 32bits/4bytes wide as part of memory. Registers will be implemented as virtual registers. Below is sample.
ADDR1 ADDR2 Registers
0 0 REG_1
1 REG_2
3 REG_3
4 1 REG_4
5 REG_5
6 REG_6
7 REG_7
There will be two different reg_map for each of agent/interface. Agent 1 uses “ADDR1” and agent 2 uses “ADDR2” addressing schemes as above table. In explicit prediction of RAL, how two different reg maps can be used to access COMMON RAL. Each register will have different access policy for each of agents. Please suggest.
Any lead would be greatly appreciated. Thanks in advance.
