I am doing AHB to APB bridge, in the scoreboard, I compare HWDATA and PWDATA but I have data in ahb driver class run phase which does not stop executing of result
i have following ahb trans file
`ifndef AHB_TRANS
`define AHB_TRANS
import ahb_enum_pkg::*; // we are using import because type definitions are scope specific.
class ahb_trans extends uvm_sequence_item;
rand bit HREADYin ;
rand rstn_enum HRESETn;
//AHB Control Signals
rand txn_enum HTRANS; // Indica tes the type of the current transfer, which can be NONSEQUENTIAL, SEQUENTIAL, IDLE or BUSY.
rand hsize_enum HSIZE; // Indicates the size of the transfer,(byte,halfword,word) max 1024bit.
rand burst_enum HBURST; // Indicates if the transfer forms part of a burst.(4,8,16).
rand write_enum HWRITE; // When HWRITE is HIGH, this signal indicates a write transfer and the master will broadcast data on the write data bus
bit [31:0] AHB_EXP_DATA;
logic [31:0] HRDATA;
rand bit [31:0] STARTING_HADDR; // 32-bit system HADDR_Q bus.
rand bit [31:0] HWDATA; // write data bus is used to transfer data from the master to the bus slaves during write operations.
rand bit [ 3:0] HSELx; //Slave select signal indicates that the current transfer is intended for the selected signal.
//AHB Outputs
bit [1:0]HRESP; //Output
rand bit HREADYout;
//port declare
bit [31:0] lower_wrap_boundary;
bit [31:0] upper_wrap_boundary;
bit [31:0] aligned_addr;
rand bl_enum BLENTH;
int NEXT_HADDR;
// for array declare
rand int unsigned hwdata_q[$];
int unsigned haddr_q [$] ;
constraint size_limit{ HSIZE inside {bytes, halfword, word};}
//constraint trans_type {HTRANS != BUSY;}
//HBURST
constraint BURST { HBURST inside {[0:7]};}
constraint EXP1 {hwdata_q.size() == BLENTH;}
constraint EXP2 {foreach(hwdata_q[i]) hwdata_q[i] < 2000;}
constraint EXP3 { if (HBURST inside {SINGLE}) {BLENTH == BL_ONE;}
else if (HBURST inside {INCR}) {BLENTH == BL_TWO;}
else if (HBURST inside {WRAP4,INCR4}) {BLENTH == BL_FOUR;}
else if (HBURST inside {WRAP8,INCR8}) {BLENTH == BL_EIGHT;}
else if (HBURST inside {WRAP16,INCR16}){BLENTH == BL_SIXTEEN;}}
constraint EXP4 {STARTING_HADDR < 1000;}
// Register with Factory
`uvm_object_utils_begin(ahb_trans)
`uvm_field_enum(rstn_enum,HRESETn, UVM_ALL_ON)
`uvm_field_int (HREADYin, UVM_ALL_ON)
`uvm_field_enum(txn_enum,HTRANS, UVM_ALL_ON)
`uvm_field_enum(burst_enum,HBURST, UVM_ALL_ON)
`uvm_field_enum(hsize_enum,HSIZE, UVM_ALL_ON)
`uvm_field_enum(write_enum,HWRITE, UVM_ALL_ON)
`uvm_field_int (STARTING_HADDR, UVM_ALL_ON)
`uvm_field_int (HWDATA, UVM_ALL_ON)
`uvm_field_int (HRDATA, UVM_ALL_ON)
`uvm_field_int (HRESP, UVM_ALL_ON)
`uvm_field_int (HREADYout, UVM_ALL_ON)
`uvm_object_utils_end
// method name : new(Constructor)
// argu : string name and handle of uvm_component.
// discription : Instead of new method use create method to create component in uvm hierarchy.
function new(string name = "ahb_trans");
endfunction:new
// BURST LOGIC IMPLEMENTATION
function void post_randomize();
// BURST CALCULATION FOR WRITE ADDR
haddr_q = {};
aligned_addr = (STARTING_HADDR - (STARTING_HADDR %(2**HSIZE)));
// WRAP BURST LOGIC
lower_wrap_boundary = (STARTING_HADDR/((2**HSIZE)*BLENTH))*((2**HSIZE)*BLENTH);
upper_wrap_boundary = ( lower_wrap_boundary + ((2**HSIZE)*BLENTH));
$display("aligned_addr = %0d, lower_wrap_boundary = %0d, upper_wrap_boundary = %0d",aligned_addr,lower_wrap_boundary,upper_wrap_boundary);
NEXT_HADDR = STARTING_HADDR;
repeat(BLENTH)begin
// FIXED & INCR BURST LOGIC
haddr_q.push_back(NEXT_HADDR);
NEXT_HADDR = NEXT_HADDR + (2**HSIZE);
if(( HBURST == WRAP4 || HBURST == WRAP8 || HBURST == WRAP16) && NEXT_HADDR == upper_wrap_boundary)
NEXT_HADDR = lower_wrap_boundary;
$display("STARTING_HADDR = %d, HSIZE = %d, HBURST = %d, BLENTH = %d",STARTING_HADDR,HSIZE,HBURST,BLENTH);
$display("STARTING_HADDR = %p",haddr_q);
$display("hwdata_q = %p",hwdata_q);
$display("--------------------------------------------------------------------------------------------------------------------------------------------");
endclass:ahb_trans
`endif
and the ahb driver as following
`ifndef AHB_DRIVER
`define AHB_DRIVER
class ahb_driver extends uvm_driver#(ahb_trans);
//Factory Registration
`uvm_component_utils(ahb_driver)
//Virtual Interface Handle
virtual main_interface.HDR_MP vif;
//AHB Transaction Handle
ahb_trans ahb_txn;
function new(string name = "ahb_driver", uvm_component parent);
// method name : start
// discription :
task start();
@(vif.ahb_drv_cb);
vif.ahb_drv_cb.HRESETn <= reset;
@(vif.ahb_drv_cb);
vif.ahb_drv_cb.HRESETn <= set;
// method name : run_phase
// argu : phase
// discription : Generate stimulus
ahb_txn = ahb_trans::type_id::create("ahb_txn",this);
// `uvm_info("ahb_driver","in run phase before forever",UVM_LOW)
start();
forever
`uvm_info("ahb_driver","in run phase after forever",UVM_LOW)
`uvm_info("ahb_driver"," get_next_item",UVM_LOW)
send_to_dut(req);
seq_item_port.item_done();
`uvm_info("ahb_driver"," item done",UVM_LOW)
//`uvm_info("ahb_driver","in run phase after end task",UVM_LOW)
endtask //run_phase
// method name : send_to_dut
// argu : req
// discription :
task send_to_dut(ahb_trans req);
//reset
@(vif.ahb_drv_cb);
vif.ahb_drv_cb.HWRITE <= req.HWRITE;
$display("HWRITE %d", req.HWRITE);
vif.ahb_drv_cb.HBURST <= req.HBURST;
vif.ahb_drv_cb.HREADYin <= req.HREADYin;
// vif.ahb_drv_cb.HREADYout <= req.HREADYout;
vif.ahb_drv_cb.HTRANS <= NONSEQ;
vif.ahb_drv_cb.HSIZE <= req.HSIZE;
vif.ahb_drv_cb.STARTING_HADDR <= req.haddr_q.pop_front();
foreach(req.BLENTH)
//repeat(9)
@(vif.ahb_drv_cb iff vif.ahb_drv_cb.HREADYout==1);
if(req.haddr_q.size()!=0)begin
//$display("starting addr = %d",vif.ahb_drv_cb.STARTING_HADDR);
vif.ahb_drv_cb.HTRANS <= SEQ;
if(req.HWRITE && req.hwdata_q.size() !== 0)begin
//vif.ahb_drv_cb.HWDATA <= req.hwdata_q[i];
vif.ahb_drv_cb.HWDATA <= req.hwdata_q.pop_front();
//$strobe("hwdata = %d,time = %t",vif.ahb_drv_cb.HWDATA,$time);
wait(vif.ahb_drv_cb.HREADYout);
//$display("blanth === %d",req.BLENTH );
//vif.ahb_drv_cb.HRESETn <= reset;
endclass: ahb_driver
`endif
and I have following output of command prompt
# aligned_addr = 752, lower_wrap_boundary = 736, upper_wrap_boundary = 768
# STARTING_HADDR = 755, HSIZE = 2, HBURST = 4, BLENTH = 8
# STARTING_HADDR = '{755, 759, 763, 767, 771, 775, 779, 783}
# hwdata_q = '{209, 514, 266, 455, 100, 739, 592, 329}
# UVM_INFO ../ahb/ahb_driver.sv(59) @ 15: uvm_test_top.env_h.ahb_hagent_h.ahb_drv [ahb_driver] get_next_item
# HWRITE 1
# UVM_INFO ../ahb/ahb_driver.sv(62) @ 195: uvm_test_top.env_h.ahb_hagent_h.ahb_drv [ahb_driver] item done
# UVM_INFO ../ahb/ahb_driver.sv(57) @ 195: uvm_test_top.env_h.ahb_hagent_h.ahb_drv [ahb_driver] in run phase after forever
while I display scoreboard data it never exit from run phase
