I have the following DUT for which i want to build a UVM env:
inputs: events_in[15:0], data_in, clk, rst
outputs: events_out[2:0]
events_in interface gets an agent and data_in interface gets an agent.
however how should events_out be handled? it’s an output only interface - should it have a passive-agent (which only wraps a monitor) or should a monitor be directly instantiated in the environment?
both work functionally but i wonder if there’s a UVM guideline to follow here.
In reply to Ofir:
The decision how many agents you have is not related to inputs and outputs, menas inputs in 1 or more agentss, outputs in another agent. The question is what belongs together with respect to the functionality. To make a decision with respect to this you have to answer the question how doeas data_in and events_in influence events_out. The solution might be to have only 1 agent covering all your inputs and outputs.
thanks, i thought about that option as well
data_in interface affects events_out just like events_in affect events_out.
data_in item is different from events_in item, which is what made me consider a different agent for each of them.
would your recommendation be to also unify the two items - and then it’s all really one agent?
In reply to Ofir:
Seperating your functionality to 3 interfaces with 3 agents might complicate your verification. As I guess all belongs together it is just easy having 1 agent. This will simplify your verification.
I agree, for the principle i would still ask,
say you have an output-only DUT (say for the example, interrupt every 100 clks).
would you create a uvm_agent for this DUT or just an interrupt monitor?
I’m trying to figure out if the UVM methodology forces me to wrap everything with an ‘agent’, or a stand-alone monitor is also ok?
In reply to Ofir:
Nobody is forcing you in the UVM. You have a lot of freedom. The agent concept is supporting in a good way the reuse aspect, because you can configure an agent passive (monitoring only) and actice (driving and monitoring). This is what you have to take in account.
Thanks for your answers, just wanted to know if there’s any guideline i missed in the methodology guide. Thank you!
