`uvm_info(get_type_name(), “inside run()”, UVM_MEDIUM)
uvc_cfg.reset_phase_objection.wait_for_obj_gt(0, uvc_cfg.reset_phase_component);
endtask : run_phase
I am getting following error for uvc_cfg.reset_phase_objection.wait_for_objection_count_gt(0, uvc_cfg.reset_phase_component);
though I confriemd through display messages that all dependent objects have been created during build phase.
Error-[NOA] Null object access
The object at dereference depth 1 is being used before it was
constructed/allocated.
Please make sure that the object is allocated before using it
Is this in a component that extends uvm_sequencer? If so, you should never define a new run_phase() for a uvm_sequencer because the existing run_phase() is needed for the component to run correctly.
If this is part of a different type of component, you will need to provide more information about your code so that we can see what you are trying to accomplish.
Yes this is extended from uvm_sequencer. This is existing axi uvc VIP and same sequencer code is for master as well as slave. For master its running well but when I took slave instance it started giving me issues. Is there any switch in UVM which can give me more detail of the error?
The error you are seeing is a SystemVerilog/Simulator error (a NULL pointer error) and has nothing to do with UVM. As I previously mentioned, by creating your own run_phase() in a uvm_sequencer, you are breaking the internal workings of UVM and the side-effects are unpredictable. I’m not sure why your UVC is doing that, but I can guarantee that there is a better way to accomplish what you are currently doing.
