UVM : Fatal Error when i am trying to get intf
Hi Friends,
I have created 8 interfaces for 8 agents.
top.sv (code) :
 //Flit interface instances
 flit_intf flit_if_0(i_we_clk,rstn);
 flit_intf flit_if_1(i_we_clk,rstn);
 flit_intf flit_if_2(i_we_clk,rstn);
 flit_intf flit_if_3(i_we_clk,rstn);
 flit_intf flit_if_4(i_we_clk,rstn);
 flit_intf flit_if_5(i_we_clk,rstn);
 flit_intf flit_if_6(i_we_clk,rstn);
 flit_intf flit_if_7(i_we_clk,rstn);
   //put in the database the interface used by FLIT Slave agent0
   uvm_config_db#(virtual flit_intf)::set(null, "uvm_test_top.env.flit_slv_agnt[0]", "slv_if", flit_if_0);
   //put in the database the interface used by FLIT Slave agent1
   uvm_config_db#(virtual flit_intf)::set(null, "uvm_test_top.env.flit_slv_agnt[1]", "slv_if", flit_if_1);
   //put in the database the interface used by FLIT Slave agent2
   uvm_config_db#(virtual flit_intf)::set(null, "uvm_test_top.env.flit_slv_agnt[2]", "slv_if", flit_if_2);
   //put in the database the interface used by FLIT Slave agent3
   uvm_config_db#(virtual flit_intf)::set(null, "uvm_test_top.env.flit_slv_agnt[3]", "slv_if", flit_if_3);
   //put in the database the interface used by FLIT Master agent0
   uvm_config_db#(virtual flit_intf)::set(null, "uvm_test_top.env.flit_mst_agnt[0]*", "mst_if", flit_if_4);
   //put in the database the interface used by FLIT Master agent1
   uvm_config_db#(virtual flit_intf)::set(null, "uvm_test_top.env.flit_mst_agnt[1]*", "mst_if", flit_if_5);
   //put in the database the interface used by FLIT Master agent2
   uvm_config_db#(virtual flit_intf)::set(null, "uvm_test_top.env.flit_mst_agnt[2]*", "mst_if", flit_if_6);
   //put in the database the interface used by FLIT Master agent3
   uvm_config_db#(virtual flit_intf)::set(null, "uvm_test_top.env.flit_mst_agnt[3]*", "mst_if", flit_if_7);
When i am trying to get flit_if_4 in master driver class it is giving below fatal error.
FATAL ERROR:
UVM_FATAL …/…/…/…/…/tb/UVM/inoc_flit_agent/master_driver.sv(22) @ 0: uvm_test_top.env.flit_mst_agnt0.inoc_flit_master_driver_inst [uvm_test_top.env.flit_mst_agnt0.master_driver_inst] No virtual interface named flit_intf in the environment
Master Driver code :
virtual flit_intf inoc_flit_vif;
        if(!uvm_config_db #(virtual flit_intf)::get(this,"","mst_if",inoc_flit_vif))
            `uvm_fatal(get_full_name(), "No virtual interface named flit_intf in the environment")
    endfunction // build_phase
Agents creation Code in build_phase task(env.sv):
    foreach(flit_mst_agnt[i]) begin
       flit_mst_agnt[i] = inoc_flit_master_agent::type_id::create ($sformatf("flit_mst_agnt%0d",i), this);
Can some one help me to fix this issue.
Regards,
Rajani
In reply to rajanikanthd:
Your problem is here:
You are passing the same interface type using the same name “slv_if”, for different instances of your interface.
You have to differntiate like this:
   uvm_config_db#(virtual flit_intf)::set(null, "uvm_test_top.env.flit_slv_agnt[0]", "slv_if0", flit_if_0);
   uvm_config_db#(virtual flit_intf)::set(null, "uvm_test_top.env.flit_slv_agnt[1]", "slv_if1", flit_if_1);
   uvm_config_db#(virtual flit_intf)::set(null, "uvm_test_top.env.flit_slv_agnt[2]", "slv_if2", flit_if_2);
You create the agent by string “flit_mst_agnt0”, but you use a path “flit_mst_agnt[0]” in the config_db. I think that’s the problem.
In reply to chris90:
After changing also seeing same problem.
uvm_config_db#(virtual flit_intf)::set(null, “uvm_test_top.env.flit_mst_agnt0”, “mst_if”, flit_if_4);
uvm_config_db#(virtual flit_intf)::set(null, “uvm_test_top.env.flit_mst_agnt1”, “mst_if_1”, flit_if_5);
uvm_config_db#(virtual flit_intf)::set(null, “uvm_test_top.env.flit_mst_agnt2”, “mst_if_2”, flit_if_6);
uvm_config_db#(virtual flit_intf)::set(null, “uvm_test_top.env.flit_mst_agnt3”, “mst_if_3”, flit_if_7);
uvm_config_db#(virtual flit_intf)::set(null, “uvm_test_top.env.flit_slv_agnt0”, “slv_if”, flit_if_0);
uvm_config_db#(virtual flit_intf)::set(null, “uvm_test_top.env.flit_slv_agnt1”, “slv_if_1”, flit_if_1);
uvm_config_db#(virtual flit_intf)::set(null, “uvm_test_top.env.flit_slv_agnt2”, “slv_if_2”, flit_if_2);
uvm_config_db#(virtual flit_intf)::set(null, “uvm_test_top.env.flit_slv_agnt3”, “slv_if_3”, flit_if_3);
I want to use master driver and slave driver for 4 agents because all are having same interface signals.
DUT has 4 interfaces
Each interface has below signals with different name but width is same
//outgoing data
logic [1:0] o_out_flit_valid;
logic[`FLIT_WIDTH-1:0] o_out_flit;
logic [1:0] i_out_flit_ready;
// Incoming data
logic [1:0] i_in_flit_valid;
logic[`FLIT_WIDTH-1:0] i_in_flit;
logic [1:0] o_in_flit_ready;
So instead of creating 4 master & slave drivers i have created 1 agent and created 4 instances
If i change interface type to different name as you said like slv_if0,slv_if1…
in this case need to create 4 drivers then only i can get seperately .
What could be the problem.
Regards,
Rajani
Where are you getting the interface? If you are getting it from driver component which is under the agent, you need to use wildcard “*” when you set config db.
uvm_config_db#(virtual flit_intf)::set(null, "uvm_test_top.env.flit_mst_agnt0*", "mst_if", flit_if_4);
I am getting in driver class.
Thanks chris …it is working …
