UVM Factory type_id::create singleton invocation
Going through the UVM base class code for uvm_registry and the create_component function, I am confused. So please pardon my ignorance here.
The create calls create_component_by_type() which invokes a get() that is a singleton. If the handle to the component/(object) already exists then it just returns it. What does this mean in the scheme of things? I
It does not prevent creation of multiple objects of the same class type, then what is the get() guarding against?
Thanks.
In reply to kernalmode1:
If you are referring to this line
obj = factory.create_component_by_type(get(),contxt,name,parent);
The get() returns a handle to a uvm_object_wrapper, which is a lightweight proxy for the the component, not the component itself.
If you want to learn more about how the factory design pattern works, check these resources:
https://verificationacademy.com/sessions/oop-design-pattern-examples
