I am learning UVM and this is a test program I wrote. So in the uvm_drv, there is a infinity blocking loop asking data from sequence. In sequence class, anything between “start_item” and “finish_item” will be passed to driver? How does the handshaking exactly happen here?
When I compile this code, I got an error message saying:
UVM_INFO top.sv(162) @ 0: reporter [top] I’m alive
UVM_INFO @ 0: reporter [RNTST] Running test test1…
UVM_INFO top.sv(111) @ 0: uvm_test_top.e.a [agent] starting sequence
UVM_INFO top.sv(53) @ 0: uvm_test_top.e.a.s [seqencer] sequencer body
UVM_INFO top.sv(73) @ 0: uvm_test_top.e.a.d [drv] I am in run phase
UVM_INFO top.sv(76) @ 0: uvm_test_top.e.a.d [drv] I am in forever loop
UVM_INFO top.sv(34) @ 0: uvm_test_top.e.a.s@@trans [sequence] sequence body
dst=054097bd, crc=7e261e9c
UVM_FATAL @ 0: uvm_test_top.e.a.s [s] send_request failed to cast sequence item
— UVM Report catcher Summary —
How should I make it correct? Thanks a lot.
1 // include package
2 `include "uvm_macros.svh"
3
4 package usr_pkg;
5
6 import uvm_pkg::*;
8 class pkt extends uvm_sequence_item;
9 rand int dst;
10 rand int crc;
11
12 function new (string name ="pkt");
13 super.new(name);
14 endfunction
15
16 `uvm_object_utils(pkt)
17 endclass
20 class trans extends uvm_sequence #(pkt);
21 pkt p;
22
23 function new (string name = "trans");
24 super.new("trans");
25 endfunction
26
27 `uvm_object_utils (trans)
28
29 task body();
30
31 pkt p = pkt::type_id::create("p");
32
33 start_item(p);
34 `uvm_info ("sequence", "sequence body", UVM_MEDIUM);
35 if (!(p.randomize())) `uvm_info ("sequence", "bad randomization", UVM_MEDIUM);
36 $display ("dst=%h, crc=%h",p.dst, p.crc);
37 finish_item(p);
38 endtask
39
40 endclass
43 class sqr extends uvm_sequencer #(trans);
44 `uvm_component_utils (sqr)
45
46 trans t;
47
48 function new (string name, uvm_component parent);
49 super.new(name, parent);
50 endfunction
51
52 task run_phase(uvm_phase phase);
53 `uvm_info ("seqencer", "sequencer body", UVM_MEDIUM);
54 endtask
55
56 endclass
57
58
59 class drv extends uvm_driver #(trans);
60 `uvm_component_utils (drv)
61
62 trans t;
63
64 function new (string name, uvm_component parent);
65 super.new(name, parent);
66 endfunction
67
68 function void build_phase(uvm_phase phase);
69 super.build_phase (phase);
70 endfunction
71
72 task run_phase (uvm_phase phase);
73 `uvm_info ("drv", "I am in run phase", UVM_MEDIUM);
74
75 forever begin
76 `uvm_info ("drv", "I am in forever loop", UVM_MEDIUM);
77 seq_item_port.get_next_item(t);
78 `uvm_info ("drv", "ph", UVM_MEDIUM);
79 seq_item_port.item_done();
80 end
81
82 endtask
83 endclass
86 class agnt extends uvm_agent;
87 `uvm_component_utils (agnt)
88
89 trans t;
90 sqr s;
91 drv d;
92
93 function new (string name, uvm_component parent);
94 super.new(name, parent);
95 endfunction
96
97 function void build_phase (uvm_phase phase);
98 super.build_phase(phase);
99 s = sqr::type_id::create ("s", this);
100 d = drv::type_id::create ("d", this);
101 endfunction
102
103 function void connect_phase (uvm_phase phase);
104 super.connect_phase(phase);
105 d.seq_item_port.connect (s.seq_item_export);
106 endfunction
107
108 task run_phase(uvm_phase phase);
109 t=trans::type_id::create("t");
110 phase.raise_objection(this, "starting");
111 `uvm_info ("agent", "starting sequence", UVM_MEDIUM);
112 t.start(s);
113 #1000;
114 `uvm_info ("agent", "ending sequence", UVM_MEDIUM);
115
116 phase.drop_objection(this, "ending");
117 endtask
118
119 endclass
122 class env extends uvm_env;
123 `uvm_component_utils(env)
124 agnt a;
125
126 function new (string name, uvm_component parent);
127 super.new (name, parent);
128 endfunction
129
130 function void build_phase(uvm_phase phase);
131 super.build_phase (phase);
132 a=agnt::type_id::create("a", this);
133 endfunction
134
135 endclass
136
137 class test1 extends uvm_test;
138 `uvm_component_utils(test1)
139 env e;
140
141 function new (string name, uvm_component parent);
142 super.new (name, parent);
143 endfunction
144
145 function void build_phase(uvm_phase phase);
146 super.build_phase (phase);
147 e=env::type_id::create("e", this);
148 endfunction
149
150 endclass
151
152
153 endpackage
154
155
156 module top ();
157
158 import uvm_pkg::*;
159 import usr_pkg::*;
160
161 initial begin
162 `uvm_info ("top", "I'm alive", UVM_MEDIUM);
163 run_test();
164 end
165
166 endmodule
