UVM Constrains inside a sequence are ignored
Hi there,
I am facing some issues trying to create some sequences, the constrains I added are not taken in consideration when the item is randomize. Do you have any idea why?
class normal_mode_seq extends default_seq;
  `uvm_object_utils(normal_mode_seq )
  constraint mode_c{
    item.mode == NORMAL_OP;
    super.new(name); // Item is created in the new function of default_seq
  endfunction : new
  virtual task body();
    `uvm_info(get_type_name(),$sformatf("Sequence randomize with %s", item.mode.name()), UVM_NONE)
    start_item(item);
    if ( !item.randomize())
      `uvm_error(get_type_name(), "Failed to randomize transaction")
    finish_item(item);
  endtask : body
endclass : normal_mode_seq
In reply to HelenLG:
Your contraint is in the wrong place. You have to use an inline constraint while randomizing the seq_item, like this
    start_item(item);
    if ( !item.randomize()with {item.mode == NORMAL_OP;})
    finish_item(item);
  endtask : body
Adding the constraint as a seperate constraint as you did is limited to the usage in the seq_item class.
You may need to share code for base class ’ default_seq ’ as I don’t see ’ item ’ being created in your current code .
Hi there,
constraint mode_c{
endfunction : new
start_item(item);
finish_item(item);
endtask : body
This is the code of the base sequence
class default_seq extends uvm_sequence #(default_seq_item);
  `uvm_object_utils(default_seq )
  rand default_seq_item item;
  item = default_seq ::type_id::create("item");
endfunction : new
task body();
  `uvm_info(get_type_name(), "Default sequence starting", UVM_HIGH)
  start_item(item);
  if ( !item.randomize() )
  finish_item(item);
  `uvm_info(get_type_name(), "Default sequence completed", UVM_HIGH)
endtask : body
endclass : default_seq
Could you paste some more code, maybe in the EDAPlayground?
It is here
Your constraint mode_c is part of class normal_mode_seq whereas you are calling randomize on handle of type default_seq_item
So item.randomize() will ONLY consider constraints within class default_seq_item
Your constraint mode_c will come into picture when you randomize handle of type normal_mode_seq
As chr_sue replied you need to in-line the constraint during call to item.randomize() for the constraint to take effect
