I have a payload which is 32 bits where i have different attributes like some tags, ids and length. The length is 4
i am trying to write a check where i want to see of one of the attributes is set to one , when it is set to one, no other attributes should be set to one.
example:
line 1- if (packet.payload[packet.length-1][3] == 1)
line 2- if (packet.payload[packet.length-1-2] & 'hae) != 0
line 3- `uvm_error()
for line 1- does this seem correct since I am trying to access the index of a particular attribute and checking if its set to 1, but what about the length in that case?
