could someone help me out in understanding below mentioned callback scenarios:
1.Drop a transaction using callbacks.
2.How the callbacks will be used in collecting coverage data.
It would be helpful is there is a example code.Thanks
Rgds,
Sudharshan
In reply to sudharshan:
I thibk you do not need callbacks for both scenarios.
In the driver or monitor you can simply drop a transaction by throwing it away.
Coverage collectors do not need a callback at all. It is simply evaluating your transacion data for your coverage model.
Hi chr_sue,
Thanks for the response.
I read that instead of Callback go for OOP. But i just want to know how to drop a particular packet in the driver class using both OOP and Callback.
could you please post me a code so that it would be helpful
Rgds,
Suhdarshan
Dropping data packets and functional coverage have nothing to do with callbacks.
Could you please tell me where you have read this?
// I hope it helps. put it all in a file and run it.
package tb_env;
`include "uvm_macros.svh"
// Basic sequence item
class shift_reg_item extends uvm_sequence_item;
rand bit [7:0] data;
rand bit [2:0] shift;
`uvm_object_utils_begin(shift_reg_item)
`uvm_field_int(data, UVM_ALL_ON)
`uvm_field_int(shift, UVM_ALL_ON)
`uvm_object_utils_end
function new (string name="shift_reg_item");
// Basic sequence
class shift_reg_seq extends uvm_sequence #(shift_reg_item);
`uvm_object_utils(shift_reg_seq)
shift_reg_item req;
function new(string name="shift_req_seq");
task body();
req=shift_reg_item::type_id::create("req");
start_item(req);
if(!req.randomize())
`uvm_fatal("shift_reg_seq","Failed to randomize shift_reg item")
finish_item(req);
// `uvm_do(req)
// `uvm_do_with(req, {req.data==8'hAA; req.shift==3'b101;})
// Sequencer
class shift_reg_sqr extends uvm_sequencer #(shift_reg_item);
`uvm_component_utils(shift_reg_sqr)
typedef class shift_reg_drv;
// Callback parent class
// here you define the method that will change the sequence
// Implementation will be done in child class
class driver_cb extends uvm_callback;
`uvm_object_utils (driver_cb)
function new (string name = "driver_cb");
virtual function void set_seq_item_value (shift_reg_drv drv, shift_reg_item item);
endfunction : set_seq_item_value
endclass : driver_cb
// Driver
class shift_reg_drv extends uvm_driver #(shift_reg_item);
`uvm_component_utils(shift_reg_drv)
// Register the callback class with this driver class
`uvm_register_cb (shift_reg_drv, driver_cb)
// If the callback is added to this driver, this method
// will call the method defined in the callback class (child callback class)
virtual function void set_seq_item_value (shift_reg_item item);
`uvm_do_callbacks(shift_reg_drv, driver_cb, set_seq_item_value(this, item))
// Call the callback method
set_seq_item_value(req);
req.print();
seq_item_port.item_done();
// This class set data bit to ones
// You can have many of this classes, each can do something else
// make sure that they are all extend driver cb
class set_seq_item_all_ones_cb extends driver_cb;
`uvm_object_utils(set_seq_item_all_ones_cb)
function new (string name = "set_seq_item_all_ones_cb");
// Override the the method that was declared in driver_cb
item.data = 8'hFF;
item.shift = 3'h3;
endclass : set_seq_item_all_ones_cb
class shift_reg_test extends uvm_test;
shift_reg_seq seq;
shift_reg_drv drv;
shift_reg_sqr sqr;
set_seq_item_all_ones_cb cb;
`uvm_component_utils(shift_reg_test)
sqr=shift_reg_sqr::type_id::create("sqr", this);
drv=shift_reg_drv::type_id::create("drv", this);
seq=shift_reg_seq::type_id::create("seq");
cb=set_seq_item_all_ones_cb::type_id::create("cb");
function void connect_phase (uvm_phase phase);
super.connect_phase(phase);
drv.seq_item_port.connect(sqr.seq_item_export);
super.run_phase(phase);
phase.raise_objection(this);
// Start sequence with out callback
seq.start(sqr);
// Here is where you add the callback functionality to the driver
// if you want to change is behaviour
uvm_callbacks #(shift_reg_drv, driver_cb)::add(drv, cb);
// Start the sequence with add callback functionality to the driver
seq.start(sqr);
// If you want you can remove to callback functionality fro the driver
uvm_callbacks #(shift_reg_drv, driver_cb)::delete(drv, cb);
// Start sequence without callback
seq.start(sqr);
phase.drop_objection(this);
endpackage : tb_env
module top;
import tb_env::*;
initial run_test("shift_reg_test");
In reply to shimonc:
I see what are you doing, but I do not really understand the value or benefit of this callback. You can do the same without the callback. Looks like Synopsys style.
Of course you can write a callback for discarding certain transactions. But you can do this also in another way.
Agree, I never used callbacks.
I usually extend classes and change there behavior.
But sudharshan wanted to see an example so I gave one.
OK, I understand.
I see the callback as an add-on and not as an alternative.
The callback allows us to make modifications without extending a class.
Thank you for the complete code
I have read in some reference document
One more clarification :
If I want to drop a packet in the driver class do I need to call item done twice ?
Example : I have generated 5 packets and I need to drop 3 and 5 packet in the driver class .is it possible?
Please let me know.
Kind Regards,
Sudharshan
get_naxt_item and seq_itrm_done has to be called as a pair.
You need an indication which sseq_items to drop, i.e. the number of the item or any other indication. In this case you are callingget_next_item()
and immediately after this item_done. This will drop this seq_item.
