Using the set_max_quit_count() method
Hi
I did some searching to find a working example, illustrating exactly how should the set_max_quit_count() method be used when the action is set to UVM_COUNT, but I could not find anything. I would appreciate if you provide an example. I think this method is defined in the uvm_report_server, and I don’t know how I should use it.
In reply to Farhad:
Do you know this:
