User defined variable
Hi all,here I have a typical code for transaction of single sequence where the number of transaction is 10.I want to give the access of user to give any value lets no_of_variable at the top level derived class of uvm_test and that will control that many number of transaction in the sequence.
Any suggestion would be appreciated.Thanks.
EdaPlaygroundLink
//================= code starts here =================//
//=============== multiple transaction exp2 ================//
//multiple transaction are done between sequencer to driver
`include "uvm_macros.svh"
package my_pkg;
//sequence_item class
class my_transaction extends uvm_sequence_item;
  `uvm_object_utils(my_transaction)
  rand logic [3:0] a;
  rand byte b;
  constraint c_a {a>5;a<15;}
  constraint c_b {b>0;b<10;}
//sequence class
class my_sequence extends uvm_sequence #(my_transaction);
  `uvm_object_utils(my_sequence)
  my_transaction req;
  task body();
    repeat(10) begin
      req=my_transaction::type_id::create("req");
      start_item(req);
      if (!req.randomize()) begin
        `uvm_error("MY_SEQUENCE", "Randomize failed.");
      //$display("a=%0d b=%0d",req.a,req.b);
      `uvm_info("my_sequence",$sformatf("a=%0d b=%0d",req.a,req.b),UVM_MEDIUM)
      finish_item(req);
class driver extends uvm_driver #(my_transaction);
  `uvm_component_utils(driver)
  function new(string name,uvm_component parent=null);
    super.new(name,parent);
    `uvm_info(get_type_name(), "in run_phase", UVM_MEDIUM)
      //#10; //time is optional,recommended to put
      seq_item_port.item_done;
//test class
  `uvm_component_utils(my_test)
  my_sequence seq;
  driver div;
  uvm_sequencer #(my_transaction) ss;//as no manual sequencer is required
    seq=my_sequence::type_id::create("seq");
    ss=uvm_sequencer#(my_transaction)::type_id::create("ss",this);
    div=driver::type_id::create("div",this);
    div.seq_item_port.connect(ss.seq_item_export);
    phase.raise_objection(this);
    	seq.start(ss);
    phase.drop_objection(this);
endpackage : my_pkg
module tb();
  import my_pkg::*;
    run_test("my_test");
//====================== END =========================//
In reply to designMaster:
This is exactly what the uvm_config_db is for. Search for Configuring UVM sequences.
