I was going through the following example given below
sfr_if SFR_IF(); // Declaration of SFR interface – This will be connected to modules
uvm_config_db #(virtual sfr_if)::set(null, “uvm_test_top”, “SFR”, SFR_IF);
In the explanation of this example I am not able to figure out the meaning of the following line
The second argument of the set() method is a string used to identify the UVM component instance name(s) within the UVM testbench component hierarchy that may access the data object. This is “uvm_test_top” here to restrict access to the top level UVM test object. It could have been assigned a wildcard such as “*”, which means that all components in the UVM testbench could access it,but this may not be helpful, and carrys a potential lookup overhead in the get() process.
Here it’s mention that “this may not be helpful” so I am not able to understand that in what way It’s not hepful.
Please reply on that if anyone have idea over it!!
