Use uvm_hdl_force to force clock
Found something interesting. I need to force the clock signal in dut.
What I did is using a static variable and created a clock. Then force DUT.clock at the right time.
                #(clk_p/2)  ref_clk = ~ref_clk;
        join_none
        #100ns;
Problem is that if I use
force DUT.clk = ref_clk;
then dut.clk will be toggling and frequency matches ref_clk
If I use
uvm_hdl_force(string_path_dut_clk,ref_clk);
then dut clk will be constant and not toggling.
Any idea why this is happening? How could I achieve force clock using uvm_hdl_force?
Thanks!
In reply to Guozhu He:
uvm_hdl_force doesn’t work the same as verilog’s force keyword, it is a one-shot operation. Just use the native verilog force.
uvm_hdl_force will force the value and remains same until release is not applied to that variable. while system verilog force will force the current value as well it will update the forced variable if current value is changed.
