hello,
i am writing my UVM scoreboard.
i want to get device configurations and encapsulate them inside a device_global_cfg_t like so:
typedef struct {
bit a;
bit b;
bit c;
bit d;
int e;
bit f;
}device_global_cfg_t;
when i declare a struct veriable using this typedef:
virtual task device_actions(tti2fcu_data_c txn);
fcu_global_cfg_t fcu_global_cfg = get_configurations ();
// // assign the expected fields of output item
// // send expected item to cmpr
endtask : device_actions
i get the following ERROR:
0.00 VCS ERROR: SE (fc): Syntax error Following verilog source has syntax error : “yakovy/UVM/SIMULATIONS/Testplan/UL_tests/mem_test/user_link_dir/scoreboard_c.sv”, 219: token is ‘fcu_global_cfg’ fcu_global_cfg_t fcu_global_cfg = get_configurations (); ^ (in ActVCSPostProcess.pm:368)
any idea why?
thanks, Kobi.
