I used the following code to copy data in the object “item” to “pkt”
$cast(pkt,item);
Then I have performed an operation on “pkt” object. But I observed that same changes are appearing on “item” also when I printed the content.
But this is not happening when I used copy() method that is available in UVM.
pkt.copy(item);
Why it happens so?
In reply to bachan21:
Can you share more test bench code on how these objects are declared and used? are they both pointing to the same object?
$cast syntax is as follows
$cast(destination,source)
It is both a type check and also an handle assignment from the source to the destination but not the other way.
In reply to hkc:
Hello,
I attach further piece of code here
`uvm_info(get_full_name(),{"\nOBSERVED OUTPUTS ::\n",item.convert2string()},UVM_LOW)
pkt = idct_sequence_item::type_id::create("PKT");
$cast(pkt,item);
//pkt.copy(item);
//Calculating expected outputs
pkt = M0.idct_process(pkt);
`uvm_info(get_name(),{"\nEXPECTED OUTPUTS ::\n",pkt.convert2string()},UVM_LOW)
After calling idct_process(pkt), both “pkt” and “item” has same interval property values which is undesired. So I used copy (do_copy) method to solve this issue so that process done on “pkt” is not reflected on “item” object.
Could you please sho the definition of ‘item’.
$cast(pkt,item) is copying the handle, not the object. After executing this statement, put and item are two class variables containing the same class handle.
See A Short Class on SystemVerilog Classes - Verification Horizons
