Hi ,
Is it possible to extend properties of reg2bus task in uvm_reg_adapter.
If possible, Example please.
Or else,
I have couple of fields, which is not listed in uvm_reg_bus_op struct (Kind,addr,…).
How to add those two fields in uvm_reg_bus_op.
Please help.
Hi ,
Or else,
Please help.
Raja.A
You can override all the function given in uvm_reg_adapter.svh and then use in your own example.
class reg2apb_adapter extends uvm_reg_adapter;
`uvm_object_utils(reg2apb_adapter)
function new(string name=“reg2apb_adapter”);
In reply to sa5691:
“You can add your fields in this fucntion .Also ,you need to change uvm_reg_tlm_adapter class to make it more generic.”
I have tried but can’t. Can you please give example to implement.
Raja.A
Hi ,
Now I can able read register which i have done write previously.
But i can not able not read Read only register.
example : reg offset is 0x05 reset value is 0x70
read value is 0x00(in predictor i getting correct value) only but i can see correct value in waveform.
Please help on this issue.
Note : Enabled provides_response bit in adapter ,
BUS : I2C , Facing issue At repeated start read (WR followed RD combined format)
